383 13.1 what heads should i go with
First off the car is a 1996 still obd2 and i currently have a 383 build with 13.1 compression ratio with ported intake and a 58mm t.b.......its a a4 with a 3600+ stall (depending on the head cam setup)
and will be spraying atleast 200 on this setup
so i need a head that will flow the numbers needed to make this engine come alive
i hope this is enough information for you guys
I was thinking of going with SpeedInc. H/I package for $1100 plus core but i dont know if there going to be any good with my set up since there rated equal to a LE1 Or maybe some Darts 200cc threw Ebay $1390shipped . I was also thinking ......Ai 190cc$1395 + Core* - Complete, Assembled, & Ready to Bolt-Oni just want the best bang for under $1500 cause im going to have to buy a Port/Polished intake to match the heads.I am about to blow my head off if i dont figure out what the hell to do
thanks
thanks
i like the afr 227 but those are a arm and a leg. I think those Darts will do the job but of course the Afr's are the way to go. LE3 package is pretty nice but you said under 1500 so i think the Darts would be the way to go since there equal to the LE2 and you can sell your stockers.
So you're planning on running 13.0:1 static compression (no mention of dynamic), with a 200 shot, on a set of $1500 cylinder heads? Ugh.
Buying the Dart or TFS heads and using them out of the box is a mistake. The real value from purchasing these heads is the porting potential that they offer.
I'm running around 12.5:1 static with a 383 with AI 200cc heads. Don't assume that you need to go with an aftermarket casting, because for most applications, ported stock-castings will more than suffice.
Out of the box aftermarkets would be a mistake on an aggressive build like that. Porting some aftermarket heads would really take that combo to a new level, but depending on what you want to do with the car and your budget ported stockers may be a better option for you.
ya 13.1compression and of course all the supporting mods. Im more concerned about the heads since i cant figure out which way to go under $1500 assembled with springs,guide plate ect. What so bad about the Darts and like "speedytransam1996" said they are equal to the le2 cause i was looking around on here and others say the samething.----how bout the trickflows 195cc
http://www.trickflow.com/partdetail....0&autoview=sku
the Dart 200CC heads flow 275CFM at .600 lift which is exactly what LE2's say they flow per there website. Dart Pro 1s, 200 cc; $1,350. On the shelf, ready to ship, delivered to your door and ready to bolt on. Sell your current heads and re-coupe some of the cost.
goals-11.20 on motor or better with a 2-250 shot id like to see 10's
lca,phb,tqr arm,kyb adj. stock trans,all supporting mods
i'd like to get a nice NA cam since i dont want to be spraying the motor always unless i have to since im going to install a hidden kit.
getting the Darts P/P threw LE wouldnt be poss.since i only have a 1500 budget
What rear you planin on using? the ten bolt? Rubber? The shocks would also need to go.
You need to get a bigger budget or smaller goals.
Often the case .
A 250 shot would not only not work well with an NA cam, but will need new pretty much everything - pistons, rods, rear end, transmission, cam, heads, fuel system, tires, gears, stall, cage if you want to run at the track, VERY good tune, etc.
The price will skyrocket well into the 5 digit range to build a true complete car ready to fully utilize a 250 shot safely.
PS: Why bottleneck such an aggressive high end build with a $1500 head limit? The heads are the most important part of any build and should have been where a big chuck of the engine fund went to.
Compression that high will be ok. Lloyd's old car seems to love it. Sorry Vanilla I don't know your name I know the car is yours now. Do some LE2 heads and get a cam from Lloyd. Obviously Lloyd's old car is doing just fine with a stroker motor and LE2's with high compression. If you get a cam from him too all you have to do is come up with about $200 more than you said your budget was to cover the cam and shipping. That's your best bet.
