2 more problems...ugh
welp i just replaced all the bulbs in my taillights because my turn signal goes on but doesnt blink...my hazards work however, but the new bulbs didnt fix anything...problem 1
number 2, my passenger headlight when it pops up the motor keeps spinning for like 5 seconds making a really obnoxious grinding sound...
any insight on either problem will be greatly appreciated
My camaro is doing the same thing with the right signal light . Sometimes the light will turn on but won't flash until i smack the dash. I believe its the from a bad ground, or thats my guess anyways.
Also after replacing the taillight bulbs the drivers side aren't as bright and when I hit the brakes the drivers side go out and the passenger side don't do anything...
there is a fuse that is behind the dash on the drivers side, kind of behind the HVAC controls. it is a round silver fuse. try replacing that and your turn signals should start working again.
I replaced the relay under the dash and it does blink now, however the right rear taillight doesn't show the light blinking or get brighter when I brake, any insight?
Ye I have the same problem with my brake light....one side does not want to work and my nephew had your problem also..
the fix..
change the rear end light harness the 98-02 has different bulb and they work much better..
the fix..
