How to figure out how much turbo you need
Old 04-27-2009, 02:03 PM
ModularTurbo's Avatar
Default How to figure out how much turbo you need
1st find cfm unboosted (CFMU):
(C.I.D/1728) X (maxRPM/2)= CFMU
2nd find Pressure Ratio (Pr):
(14.7+Desired boost) / 14.7=Pr
3rd find CFM boosted (CFMB):
CFMU X Pr= CFMB
4th convert CFMB to LB/min:
CFMB X .07= (required LB/min)
5th look at the comp map and use your required LB/min and Pr to place yourself on the map, trying to be in the lower right hand corner of the efficiency islands.
I hope this helps,
Rob@modularturbo
Old 04-27-2009, 03:46 PM
MIGHTYMOUSE's Avatar
nobody has a desired boost, how about work it out with desired horsepower. then pick the smallest turbo you land in the sweet spot on.
Old 04-27-2009, 06:47 PM
Thats a good idea LOL
OK lets inverse some things
Desired HP / 10 = required lb/min
then solve for CFMU using required lb/min like this:
lb/min / Pr = CFMU
.07
1728 X CFMU = CID
(maxRPM X 2)
Old 04-27-2009, 07:07 PM
topend's Avatar
1728 to convert to cubic feet not 1726.
Old 04-27-2009, 07:17 PM
Thank you
Updated
Old 04-27-2009, 07:35 PM
Josh@KY-Turbo's Avatar
Put the biggest turbo you can fit. Use C02 to hold the WG shut to get it to spool. Hope like hell the engine enjoys your decision.
Sorry. I had too.
Old 04-27-2009, 07:58 PM
HUNTER02SS's Avatar
Sorry. I had too.
LOl, this is the same philosophy I use!
Old 04-27-2009, 08:05 PM
87silverbullet's Avatar
^^^ I like that one. It simple and 50% effective. Just hope you're on the better side of the 50 %
Old 04-27-2009, 09:28 PM
or just do that
Quick Reply: How to figure out how much turbo you need
