Quick question about cam swap.
I'm helping a bud change out a cam on his car. As soon as we took the timing cover off. We put the old crank bolt back in and tried to turn the engine with a rachet and the 24mm socket that goes over the crank bolt. We just wanted to see if we could get a look at the dot on the crank gear, but the engine is really tough to turn and we didn't wanna damage the crank snout with the bolt. Is this normal? Do we need to remove the spark plugs? When we were tryin to turn it, we could hear some wierd compression noises so we stopped. Like i said, we were just tryin to locate the dot on the crank gear. thanks
That doesn't make sense. Pull all the plugs, you are moving the pistons and trying compressing any air in the cylinders. Since the rockers are loose, the valves won't open, and the air can't get out. Pull the plugs and you de-compress all the chanbers and the engine spins much easier.
Well we were hoping to not touch the valvetrain. Just recently he had a shop install a small cam and some comp 918's and hardened pushrods. Then he decided after about 500 miles that he wants a bigger cam So we don't need to change the springs. Is it a must to remove the springs to get everything to line up?
Russ
You are not going to change the cam without messin' with the valvetrain. Keep them in order, but the rockers and pushrods need to get out of the way. Valves springs should be fine. You need to shoot the lifters into the retainers, and then run a dowel or rod down the gallery to make certain they don't fall. If a lifter falls, life gets a little harder.
you have to pull the rockers off, get the lifters up off the lobes and then pull it out. and a very good idea to hold the lifters up and pull the PRs out too....
not a big deal to pull the rockers and the pushrods....
oh, i know its obvious, but i didnt see it mentioned......take it outta gear when trying to turn the motor over with the crank pulley bolt
