4" crank,6.125 rods=?
Old 04-28-2009, 04:53 PM
SICKSS/Z28's Avatar
Exclamation 4" crank,6.125 rods=?
i have a 4" eagle crank and eagle 6.125" rods out of a 408 can i have them installed in a aluminum block? as long as i buy new rings for the .30 bore pistons?
Old 05-01-2009, 07:20 AM
SSdreamz's Avatar
someone correct me if im wrong but i dont think you can bore a LS1 alum block .30
Old 05-03-2009, 11:18 AM
SICKSS/Z28's Avatar
ya i think i have to buy an ls2 block or use other pistons like a 3.905=383 i belive
Old 05-03-2009, 12:19 PM
PREDATOR-Z's Avatar
You can use the crank and rods but you'll need a piston set to match your bores.
408 is 4.030 bore and LS1 bore is 3.898, slightly bored can be 3.905.
Old 05-04-2009, 01:45 AM
InsaneDomestics's Avatar
So are you wanting a 408 as well or are you just going to use the parts that came out of the 408? What block do you have or are you getting? If you have and LS1 you cannot do a .030 Bore like SSdreamz said. If your going to get an LS2 then you can do a .030 Bore and still have your 408. Let us know what block you have or which one your gonna get and we can help you out a little more. To go ahead and answer your question Yes you can swap your Crank & Rods over to another LS-Series Engine.
Old 05-04-2009, 02:52 AM
PREDATOR-Z's Avatar
LS2 would only be a 402 with a light hone.
Old 05-04-2009, 03:53 AM
Right....with a 4.00 Bore. How far can you Bore an Alum LS2? I know on the Iron Block you can do at least .030, Maybe more but I dont know. Can you do .030 on the Alum. LS2?
Old 05-04-2009, 06:30 AM
SweetS10V8's Avatar
NO, from what I have read it can take a light hone only. About .005".
Old 05-04-2009, 07:31 AM
Ok, so pretty much just like the LS1 (Very Little) I kinda thought that but I wasnt for sure. Thanks!
Old 05-04-2009, 07:34 AM
Fireball's Avatar
hmmm...guess my .010 overbore LS2 (closer to .012-.013) is no good then
Old 05-04-2009, 09:10 AM
PREDATOR-Z's Avatar
Would that be considered maximum allowed? How much meat was left on the linings?
Old 05-04-2009, 09:21 AM
Fireball's Avatar
thats the furthest we're going to take mine...
Old 05-04-2009, 09:25 AM
Jon@Texas-Speed's Avatar
You can typically get away with up to a 4.020" bore with an LS2 but that is pushing it IMO. (Especially on a power adder build.) We haven't seen an issue at all going 4.010". If you are wanting to go .030 over on a 4" bore, you need to look into a 6.0L iron block. However, there really won't be much of a gain in only .010-.020 of bore size difference. At the point you are buying pistons, get them the smallest the block will clean up at. That way you still have room for clean up down the road and keep the sleeves as thick as possible.
Jon
Old 05-04-2009, 06:13 PM
Restricted User
98Z28CobraKiller's Avatar
I took my LS2 to 4.035. It ran for a while until I wasted a rod bearing (oiling problem) making a pass. Then it broke the rod and the sleeve in that order.
Old 05-05-2009, 11:57 AM
SICKSS/Z28's Avatar
i have a 408 rotating assem to use the .30 pistons that came with it my only option is to use an iron block otherwise i have to buy pistons for either a 402 or 383? ls2 block being the 402 and the ls1 block being the 383?
thanks for all the help guys
