Best Tires to Buy
Best Tires to Buy
Looking to getting new Tires on the back, size 275/40-18's...not really looking to spend any more then $200 per tire(less if possible) My car is basically stock and really only driven on the weekend(less then 5k a year). Looking for a tire that is going to grip well but not kill my wallet...Was looking into the Nitto 555 EP's...is there any other tires i should look into or are those my best bet? if so where is the cheapest place i could get them from
I just bought a set of General Exclaim UHP tires from the TireRack and I couldn't be happier with them! They got great reviews and I took a chance with them and like them. I went with 275/35/18 for $168 each (+ a $50 Visa gift card). 275/40/18's are only $154 each. However, if you want CHEAP, the Hankook Ventus S1 evo is on clearance for $109 each right now. But I know NOTHING about it.
any reason you are getting 275/40/18 over 275/35/18??? The latter will keep you with a stock height tire. BFG g-Force Sports are under $200 and they have been a great tire for me so far.
i can put 2 put 275/35/18's with no problems? i just know the stock size is 275/40/18 so i figured i would keep them the same...also does anyone have any experience with the sumitomo's? i have no problems spending 190 each for the Nittos cuz i know they are a good tire but if the sumitomo's are just as good and cheaper ill get those
[QUOTE=BandDirector Blk98ZM6;11526813]I just bought a set of General Exclaim UHP tires from the TireRack and I couldn't be happier with them! They got great reviews and I took a chance with them and like them.QUOTE]
+1 Same deal took a chance and love them. Always used Fusions before. Better wear and traction for the money.
245/50/16(stock size)=275/40/17(stock size)=275/35/18=25.6"
275/40/18=26.66" (too tall in my opinion)
the wheels themselves don't really care what size tire you put on them, as long as the inner diameter matches, but if you put a taller or shorter tire than what came on the car stock (and by taller/shorter, i mean overall tire height, not sidewall height), it's gonna screw with your speedometer.
[QUOTE=Breathing Fire;11532022] I was looking at these tires myself.
Ever take them to the strip? How do they hook? Or how do they hook on the street, for that matter?
Thanks!
Thanks!
ok...well what if i am going to put rims that are 17x8.5 in the front and 18x9.5 in the back in a 98 camaro what size tires should i be putting on?
then I guess you could go with 245/45/17 front and 275/40/18 in the rear. The 17/18 combo is harder to work with since you want to have a 1" taller tire in the rear to keep the sidewall width consistent with the front but I hear that a 1" difference in front and rear tires will confuse the ABS.
245/45/17 front
275/35/18 rear
If you want a slightly taller tire (~26") go with
255/45/17 front
285/35/18 rear
The latter is what I went with for my 2000 vette rims. (17x8.5 - 18x9.5)
Went with a slightly wider setup because I am known for dragging my tires against curbs and wanted to avoid rim damage.
275/35/18 rear
255/45/17 front
285/35/18 rear
