Cam only-whats allowed?
Im looking to stay cam only see how far I can go. My question is where does the line get crossed. Milled heads allowed? Flycut piston?
it depends on what you feel comfortable with, and how comfortable you feel with lying to yourself... tech cam only means cam only- no nothing, nada, zilch
now to be safe you flycut pistons for clearance, add springs, retainers, lifters, pushrods, timing chain, so on and so forth
in short- id say the line is when you touch a tool to the head that isnt to replace/ repair a part on that head
I agree. Im cam only now but thinking about going with a different cam which would involve notching the pistons. I wanna leave the heads stock unmilled and unported with stock gasket.
Ok, I get the engine part of the equation. How about engine swaps? Is cam only just for the fourth gen Camaros and Firebirds? Can you have a LS motor in a third gen Camaro and still set the record? Just curious because my car will be ready shortly and I was going to go for the record. The motor is the last piece so, if I can't be a contender for a cam only record, I will put it together a little differently. Thanks, Mike.
i consider the record for lSx's to be in car that come stock in LSxs... like an ls2 in a gto, ls1 in a camaro, ls6 in a vette so on so forth... once you change the car its not a record for the fastest cam only ls1, its the fastest cam only ls1 in a 3rd gen..... or the cam only lists would be filled with rx7s and miatas
the way i feel about it. what should be allowed.
stock heads untouched except for springs for increased valve lift
fly cut pistons
rod bolts
timing chain and oil pump
as long as you have stock crank, stock rods, stock pistons and untouched heads
youshould be fair game
fly cut pistons
rod bolts
Just curious how big of a cam are you looking to put in there if its going to require flycutting ? Is your vette a zo6 i forget ? I believe ls1joe( i think thats his name) went to a bigger cam and flycut the pistons hes #2 all time. Milling the heads isnt allowed. Also I think a stock head gasket it required to keep the compression the same as stock.
Looking at the cam-only list... stock long block, with whatever accessories it takes to run the cam(springs, rockers, flycutting). Definately a cool little catergory to build for. I'm building one myself.
