Looks like ill be in the 10s this year
Old 05-02-2009, 04:31 PM
AChotrod's Avatar
Default Looks like ill be in the 10s this year
Just bought this & Ill need a kit soon! Im still working on the 396 built but thats gonna take some time. This was to good a deal to pass up.
ENGINE BLOCK=Hot Tanks/bead cleaned
Hone&bore .030 over
Torque plate bore service
Line hone mains
OE cast crank shaft cut 10/10
OE connecting rods reconditioned
balanced assembly, short block was assembled and clearenced
PARTS LIST=Clevite bearings mains/rods
TRW forged pistons 10.1 compression
Seal power molly rings
ARP rod bolts
New freeze plugs/gally plugs
That should handle my rpms, and a nice kit.
Old 05-02-2009, 04:50 PM
gregrob's Avatar
Spray it dont say it!
Sounds badass man
Old 05-02-2009, 04:56 PM
integraxtc's Avatar
^^lol
Old 05-02-2009, 04:58 PM
AChotrod's Avatar
I wont say how much N2o!
Old 05-02-2009, 06:06 PM
My96z's Avatar
From what I have read, those TRW forged pistons are pretty stout. I read in a Car Craft magazine awhile back they sprayed I think a 400 shot on a budget rebuild Chrysler 440.
I have a question for you, how many RPM's are you plannning to turn? When do you need splayed caps? I am building a 355 when I get back.
Old 05-02-2009, 06:12 PM
AChotrod's Avatar
Well it probably should get splayed caps but, from what i hear the 2bolt can take a beating and the majority of failers are pistons or rod bearings. Ill be building a 396 with splayed caps, or if its not to crazy Ill have them done to this block b4 it goes in.
Old 05-02-2009, 06:28 PM
My96z's Avatar
I hear of lots of guys spinning bearings when they rev their engines with head and cams kits. I just want to avoid that with my build. I didnt know if thats just the way the stock bottom ends are or if the splayed caps helped or what, or if its just better aftermarket bearings.
Jeff
Old 05-02-2009, 06:44 PM
speed_demon24's Avatar
Jeff
That's from poor work on their part, letting dirt get into the engine, ect. My car has had 3 head swaps and 4 cam swaps that I know of and it's hit the 6700 limiter more times than I can count.
Old 05-02-2009, 07:11 PM
joelster's Avatar
I never understand when it says "10-1" pistons on a shortblock, when the cylinder head plays a huge part in determining compression ratio. You need to get a part number off of those pistons to find out exactly how much cc's of valve relief their is, and then you can determine the compression ratio from there, assuming you know what head gasket you are running.
Old 05-02-2009, 07:14 PM
AChotrod's Avatar
Jeff
Im sure it happens, but pretty much depends on the parts you choose and the condition of the motor.
Old 05-02-2009, 09:54 PM
robsquikz28's Avatar
you bought that off of Ken huh...
Old 05-03-2009, 07:04 AM
z28rob18's Avatar
so noone asked yet. how much? i think your stock block woulda been in the 10s wit spray
Old 05-03-2009, 07:43 AM
My96z's Avatar
Would you guys feel comfortable spinning a new GM LT1 stock shortblock to 6800? Lots of good deals floating around on new GM shortblocks 2 and 4 bolt main.
Old 05-03-2009, 11:25 AM
AChotrod's Avatar
I got a great great deal. he started at 2000, with a cam and bone stock heads. I told him to keep the cam and heads & ended up paying $800+ a bare short I was gonna build my 396 with. Now I can just swap this one in and use my factory block for the 396.
4bolt mains are WAY better but the majority of spun bearings are ROD bearings because the factory rod bolts stretch at higher RPMs.
Oh Im sure that my factory block would go 10s easy, but not for very long spinning to 6800. This is for pc of mind and going with a bigger shot than the factory pistons can handle.
Jolster,
I beleive the compression is measured of a factory stock head. Lloyd thinks this will work perfect fo what I want to do with it, and Ill be using
MR G 5716s wich are .026.
Old 05-03-2009, 11:33 AM
Elliott's94Z's Avatar
Sounds badass man
Lol! True true...
Sounds like another great build coming from AC! So you and I both are looking to pull wheelies here sometime soon huh Keep us informed bro!
Elliott
Old 05-03-2009, 11:53 AM
z28rob18's Avatar
you should get the car to hook as is first to see wat itll lay down wit a decent 60 and keep us posted
Old 05-03-2009, 12:26 PM
AChotrod's Avatar
As soon as my clutch arrives Im sure Ill pop a tire up. It almost pulls one on the stock clutch leaving at 4500, street twin and a 6k dump im sure it will lift up.
Old 05-03-2009, 04:04 PM
LS1 SPEED's Avatar
2 bolts are good if the motor is built properly. The 96 I had with a 383 S/R setup went to 7K RPM and a 200 shot. The car was 3500ish lbs and went 9.7@138 7 years ago.
never broke!
Mike spray this setup now and have that motor ready
Old 05-03-2009, 08:42 PM
AChotrod's Avatar
That sounds fun, but I dont want to **** the rest of the motor.
Old 05-03-2009, 09:15 PM
C5042081's Avatar
is this gonna be a solid roller build?
