Help!
Help!
I dropped a new tranny in my car. Everything seems fine except when I brake and then let off the pedal it revs up. I checked the vacuum hoses I could see and they looked fine. Anyone got any suggestion?
LS1Tech Sponsor
I would not really have any suggestion there, Vaccume would be a first check. I would also check for and pinched or broken wires and over the entire installation. Now if the converter has changed stall that could affect it also.
But do you actually mean by chance if you brake and let off the petal while driving the rpm jumps up then comes back down when you are at a steady throttle maybe ?
__________________
I tried finding vacuum diagram but couldnt find anything. I'm going to put it back on the lift this weekend and double check everything make sure nothing came loose before I take it to a shop.
