LS1 C3 Vette guys!
LS1 C3 Vette guys!
I'm finally paying off my 2000 SS Camaro and want to start saving up for a 68-72 Corvette. I love my LS1 and would like to put in a LS1 with a T56 in when I get one. I'm just curious about how hard it was to do it and what had to be done to get everything to work. Did you have to cut the trans tunnel up to get the shifter in the right spot or anything? any info/stories would be great. thanks.
im am currently in progress of doing one. only thing is mines a 4l60e trans. but yes you'd have to do some cutting and stuff. Your best bet is to look at
Corvetteforum.com and go in the the c3 section theres a buncha treads on them.
good luck when you get yours going
Ya I've been searching the forums alot. I think when I do it I'm going to go with the Edelbrock performer RPM carb set up. I researched it and it would make the whole swap alot simpler.
I put an LS1 / T56 combo in my 79 C3 a few years back. My C3 was original TH350 auto, so I also removed pedal assy and got clutch pedal assy). I pounded the tunnel a bit and did cut for the shifter. It is a 'bit' of work (include replacing many parts in the 30 to 40 year old C3 unless it had been recently gone through) but worth the effort IMHO. I kept mine electronic fuel injected and got HP Tuners to tweak it, a few folks on CF have gone with carb setups. I live in Calif and had to get it smogged as a 1999 vette by the ref station.
Couldn't find any pics of just the hole I cut in the tunnel - it was pretty big, I riveted/bonded in an alum plate to recover a lot of the hole before covering it up while still allowing dropping tranny.
Here are a few pics though - a couple with the aluminum plate console I put in (expect to redo it in the future) and a couple while putting in reflectix over homemade lizardskin for heat/insulation. I didn't put an offset on the shifter (stock f-body cut down) - which one would want if they retained the stock console for the shifter to come up in the right place. I don't have any problems with shifter location as is.
The shifter is in first, needed the hole pretty wide to accomodate 5th/6th and reverse.
79 Corvette
I've got a '79 that currently has an old school small block and a Tremec TKO 5 speed. I'm also considering an LS1 swap with the Edelbrock intake and a Demon 650 that I just bought new a few months back.
I think I have the trans figured out... GMPP makes a spacer for the flywheel/flexplate and a stepped bushing to move the flywheel mounting surface back 0.400" (the LS1 crank is shorter by this amount) and I believe I should be able to use my existing flywheel and clutch, I also run a hydraulic throw out brg that should work. According to all I've read I should be able to use the old bellhousing as well.
My biggest question is accessory drives for the front of the motor... the upper a-arms are close to the motor and it seems power steering pump and ac compressor mounting may be a problem??
I've got an LQ9 with a GM Richmond 6 speed in my 68 vette.
I mated the GM 168 tooth bell housing "621 style" with no problems. The 153 wont work.
You dont ned to move the flywheel back. How would the starter engage if you did that? You just need The adapter pilot bushing. Either the stepped or the LS7 pilot bushing. I used the LS7.
Your SBC flywheel wont work. Just get a complete LS1,2,6, or 7 setup.
You can get your manual clutch to work or go hydraulic. I used the manual Z bar linkage.
anyone able to get the shifter in the stock position so you can use the old console? I know Keisler makes a whole kit to do it, but that probably costs something ridiculous and they don't sell the adapter unless you buy the whole kit, at least I think.
I'm stockpiling parts for the swap in my 71. I'm also going to be running the edelbrock carb setup, but am running a 200-4r. I spend alot of time on corvetteforum.com and you'll get a lot of help there. speedhound.com has the parts you'll need for the swap, mounts, waterneck, and headers. I'm using a stock F-body pan and front accessories which seems to be the easiest and popular setup for the c3 swap.
if you are going to do a conversion read corvette forum. it's long but has a lot of information for you. as far as the motor mounts go, use these mounts for using a t-56 http://carshop.carshopinc.com/produc...458/C/S%202372 and you don't have to move your shifter location. supposely. hope this helps.
go to this web address http://forums.corvetteforum.com/c3-t...directory.html there is a couple of guys that have swap the t-56 and they posted there email address. they would be able to help you out more. i got a killer deal on a auto so i went that route on mine.
sorry to bring up an old thread but i had to compliment martinsw on his interior, it looks sweet! my project is still in progress but hey i expect to have it done before summer's over
X2 on the compliment, that guys custom console looked like pure sex! I wonder if......
mrmarchuk and deuce4935,
Wow - suprised seeing this thread come up again after over a year (and I still have not turned the alum console panels as I have been planning).
Thanks for the kind words on my car - a labor of love, have done nearly all of the work myself - mostly in the driveway. The alum speedo and gauges consoles were easy to make, and deuce - NO I DO NOT HAVE SEX with my car .... ...kissing is another story though (LOL)!
I am definately enjoying driving the C3 LS1/T56 - use it to commute to work about once a week (90 mile rt). Got many good inputs from folks on this forum, and the vette forums when doing the conversion, would have been lots more difficult without the resources.
mrmarchuk - I/ve checked out your web site and have viewed your conversion posts in the other forums - kudos to you,your car is looking real fine, get it back on the road before summers end and enjoy. I notice you have a link to Josh's new vette business, and that you have AC on your C3 - I got the first R4 AC bracket running with him the other year, and having the AC work again makes driving the C3 in san diego alot more enjoyable. And congrats on the upcoming son, I am sure you will enjoy doing things to the vette in the future with him (these projects are never done)!
and thanks again the swap started late last winter and thats why i dont have it finished yet but time to step on it im leaving on a 2 week trip on tuesday and when i come back, i plan on putting myself on a schedule to finish the car
Hey martinsw, I remember your swap from when I first joined CF back in july '07. I loved your swap because you were able to keep it legal in CA.
I do have a question: what thickness of aluminum did you use for your console plate? I'm going the same route. Thanks and glad to hear you're still enjoying the vette
I used 0.090 al plate (~ 3/32") for the console plates. I used sandpaper to give it the brushed look, and sprayed on a clear coat to reduce scratching. The clear coat was cheap rattle can and it still scratched some. Someday I plan to use some ~3/4" dowel and give them the jeweled (turned) look.
Smogging the conversion in CA was challanging, now the smog stations just hook me up and test like it is a 2000 corvette. Have retested twice since getting the ref station to approve it, passed with flying colors both times. Kind of a hassle as I put on the air injection pump stuff before testing, then remove it after to ensure I pass the visual (isn't even wired up, just looks like it),
Steve
Hi Greg,
Steve
Steve
i ended up switching to an ls1 instead. alot more power/more efficient
and thanks for the measurements.. i might have to look into that or at least keep it in mind when redoing my center console
