LS1 C3 Vette guys!
Corvetteforum.com and go in the the c3 section theres a buncha treads on them.
good luck when you get yours going
Here are a few pics though - a couple with the aluminum plate console I put in (expect to redo it in the future) and a couple while putting in reflectix over homemade lizardskin for heat/insulation. I didn't put an offset on the shifter (stock f-body cut down) - which one would want if they retained the stock console for the shifter to come up in the right place. I don't have any problems with shifter location as is.
The shifter is in first, needed the hole pretty wide to accomodate 5th/6th and reverse.
I think I have the trans figured out... GMPP makes a spacer for the flywheel/flexplate and a stepped bushing to move the flywheel mounting surface back 0.400" (the LS1 crank is shorter by this amount) and I believe I should be able to use my existing flywheel and clutch, I also run a hydraulic throw out brg that should work. According to all I've read I should be able to use the old bellhousing as well.
My biggest question is accessory drives for the front of the motor... the upper a-arms are close to the motor and it seems power steering pump and ac compressor mounting may be a problem??
I mated the GM 168 tooth bell housing "621 style" with no problems. The 153 wont work.
You dont ned to move the flywheel back. How would the starter engage if you did that? You just need The adapter pilot bushing. Either the stepped or the LS7 pilot bushing. I used the LS7.
Your SBC flywheel wont work. Just get a complete LS1,2,6, or 7 setup.
You can get your manual clutch to work or go hydraulic. I used the manual Z bar linkage.
Wow - suprised seeing this thread come up again after over a year (and I still have not turned the alum console panels as I have been planning).
Thanks for the kind words on my car - a labor of love, have done nearly all of the work myself - mostly in the driveway. The alum speedo and gauges consoles were easy to make, and deuce - NO I DO NOT HAVE SEX with my car ....
...kissing is another story though (LOL)! I am definately enjoying driving the C3 LS1/T56 - use it to commute to work about once a week (90 mile rt). Got many good inputs from folks on this forum, and the vette forums when doing the conversion, would have been lots more difficult without the resources.
mrmarchuk - I/ve checked out your web site and have viewed your conversion posts in the other forums - kudos to you,your car is looking real fine, get it back on the road before summers end and enjoy. I notice you have a link to Josh's new vette business, and that you have AC on your C3 - I got the first R4 AC bracket running with him the other year, and having the AC work again makes driving the C3 in san diego alot more enjoyable. And congrats on the upcoming son, I am sure you will enjoy doing things to the vette in the future with him (these projects are never done)!
yeah if you ever decide to get rid of that center console aluminum, let me know
(shifter plate and the gauge cluster) i will be redoing mine since i plan on making the 01 fbody gauge cluster work on it, it might be alot of work but it will be different and will save me a ton of money instead of having to buy autometer gauges, plus that will leave the center cluster area empty so i can put in a dvd or navi
i pulled all the harnesses and stuff that i'd need off that SS camaro that i pulled the engine off of so i have everything i need to get it done except fuel lines and the harnesses need to be modded (which will require alot of thinking before cutting anything apart lol)and thanks again
the swap started late last winter and thats why i dont have it finished yet but time to step on it
im leaving on a 2 week trip on tuesday and when i come back, i plan on putting myself on a schedule to finish the car
I do have a question: what thickness of aluminum did you use for your console plate? I'm going the same route. Thanks and glad to hear you're still enjoying the vette
I used 0.090 al plate (~ 3/32") for the console plates. I used sandpaper to give it the brushed look, and sprayed on a clear coat to reduce scratching. The clear coat was cheap rattle can and it still scratched some. Someday I plan to use some ~3/4" dowel and give them the jeweled (turned) look.
Smogging the conversion in CA was challanging, now the smog stations just hook me up and test like it is a 2000 corvette. Have retested twice since getting the ref station to approve it, passed with flying colors both times. Kind of a hassle as I put on the air injection pump stuff before testing, then remove it after to ensure I pass the visual (isn't even wired up, just looks like it),
Steve
Steve
i ended up switching to an ls1 instead. alot more power/more efficient
and thanks for the measurements.. i might have to look into that or at least keep it in mind when redoing my center console
