lt1 timing chain
lt1 timing chain
have the motor apart. and i don't need the gears that run the mech. water pum since im going ewp? just wanted to see if i could get a heavier duty timing set without having to get the expensive lt1 timing kit since im not going to have the mech. water pump anymore? am i wrong?
I edited my post, I meant which one besides the 3146, summit has two on there for some reason.
http://store.summitracing.com/partde...6&autoview=sku
http://store.summitracing.com/partde...0&autoview=sku
It notes that it won't fit the LT1 because of the water pump drive mechanism (this is obviously null and void when using an EWP).
cool. i knew there was an alternative since i was going ewp. since i was eliminating the mechanism, i wanted to see if anyone was able to put a double roller in there. thanks ramair and slp
Keep in mind that I'm fairly sure you're going to need the 95-style timing cover, as it offers extra clearance (not 100% sure though, you may be able to get away with the 96-style). The cover MAY need minor clearancing on the back side as well (mine did). But it was worth it.
Hmm. Well the block that's being machined is a 95 lt1. Is there a CPS on 96 b body lt1's? ouch... I'm going to have to look at my car now lol
