WTB: Factory LS1 GTO Driver Side Manifold and GTO Front Sump Set-Up.
Hey guys as the title states. I need a driver side GTO factory exhaust manifold. I also need a complete LS1 front sump set-up. I have an F-Body rear sump set-up now and am willing to trade.
Thanks.
Thanks.
Thanks.
I see you found Supra8's build up of a MK2 supra w an Ls1!!
I'll be looking for the same as soon as I find and engine (got tired of the 2jzgte engine/turbo bs)
Good luck and post some info-I'm going to look at using a GTO ls1 prob....but we shall see what I can find.
Are you going to cut and shorten the gto oil pan? or just notch the K member.
Cheers
Brian G
Cheers
Brian G
Cheers
Brian G
Cheers
Brian G
Please! Keep me posted man!!
I've swapped in a tru track w 3:73's, I'm on the lookout for an Ls1 or Ls2 engine and an f-body T56 (can't find any reasonable prices-don't want to piece together a 5.3/the truck manifold won't fit under the hood
How far is the front eng acc's from the rad? Did you set the engine closer to the fire wall or is Kieth's design the best method?
Also, do you think a batwing oil pan will fit?
Man, I wish a truck engine/manifold combo would fit-that would save me/us a lot of trouble..
Good luck and keep us posted.
Brian G
Brian G
