can a 700r4 be converted to a vss
Old 05-04-2009, 11:37 PM
Jmreaper's Avatar
Default can a 700r4 be converted to a vss
hi i just got a 700r4 for free and i had a 4l60 with the vss will the tail shaft just bolt on and work or wat do i have to do and also wat wires do i have to hooke up coming out of the 700r4 to go into my ecm?????
Old 05-05-2009, 02:18 AM
LS1Tech Sponsor
performabuilt's Avatar
What are you putting it in would be the first question
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 05-05-2009, 10:40 AM
2002CAMAROSSLS1T56's Avatar
What vehicle?
Generally if it had a 4L60 or a 4L60E with a VSS you should be able to plug it right back in. If the plug doesn't work splice the correct on one.
Old 05-05-2009, 02:50 PM
Jmreaper's Avatar
its going into 95 camaro i have the old 4l60 tranny it dead tho but cant i just switch tail housing shafts? cause i notice the 700r4 had the cable drive and it has a plastic gear on it and the 4l60 has a metal one does this matter??? or do i have 2 switch them
Old 05-05-2009, 04:02 PM
You need to use the original sensor and reluctor wheel. (or ones just like them)
The sensor is one bolt, and it's out. The reluctor wheel, good luck removing and reinstalling it without the proper tools. If both transmissions are out maybe swing by a trans shop with them in the bed of a truck ready for the swap.
Old 05-06-2009, 08:35 PM
Jmreaper's Avatar
ok i got the old parts but how do i get the duster cover off the 700r4 that behind the plastic gear, i see 2 little holes should that cover pull right off
Old 05-06-2009, 09:06 PM
Thats why I say take it to a trans shop.
I don't know what the **** a duster cover is, probably governor cover.
Now...Why would you disassemble THE ENTIRE TRANSMISSION just to swap an output shaft because of the speedo gear/VSS wheel?
You can take the plastic gear off and throw it in the trash, you need to replace it with a metal VSS reluctor wheel. You need special tools to remove one. You might get by using a metal pipe to tap one back in place.
Thats why I said before you need to reuse yours, or another one. If you can find one laying around a trans shop, you can tap it on yourself.
If you want to try and reuse yours, you can use a bearing puller (not a jaw type puller, a bearing puller) and some long allthread rod to remove it.
Tearing the whole trans down to change the output shaft is not the way to swap a VSS reluctor.
Just wondering, how are you going to connect the TV cable to the throttle body?
Old 05-06-2009, 10:07 PM
Jmreaper's Avatar
i didnt take the whole tranny apart i just had a 4l60 from my camaro and i got a 700 r4 for free so i took both tail housing off and i am geting a new vss ring cause the one that was in the 4l60 it was nsty lookin but i got the plate from a 93 camaro they came with 700r4 and it bolts too tpi
Old 05-06-2009, 10:35 PM
Well it sounds like you're on the right track. In fact it doesn't even sound like you need help here, you got it.
Old 05-07-2009, 01:01 AM
Jmreaper's Avatar
but do u know wat i have to wire up for the 700r4 plug? i have the plug but wat do i have to wire into the harness
Old 05-07-2009, 12:52 PM
The plug that went to your old VSS
Not really sure why exactly you're asking such a simple question.
If the plug is different just cut it off and splice the right plug on.
Old 05-07-2009, 01:30 PM
Jmreaper's Avatar
i know that but do u know how the 700r4 has onther plug that plugs into it besides the vss u know how too wire the a4 conneter
Old 05-07-2009, 01:45 PM
You mean the square connector up on the drivers side above the pan rail?
Thats for the TCC.
There are too many wiring configurations to explain that not knowing what you have.
I used to always rewire them to operate the TCC solenoid off a factory pressure switch so it automatically locked up in 4th.
I also always wired them to a three position toggle switch so it could be switched for automatic lock up, manual lock up, no lock up.
You can also buy these parts in kit form.
And you can always just drop the pan and wire the TCC solenoid direct to the plug so you can just connect it to a manual switch by sending 12 volts to it.
And there are also TCC solenoids that are grounded that operate by applying 12 volts. Some have two wires and 12 volts going straight to it and are controlled by the ground side.
You'll need to get some pics up if you want to get into all that.
Or a detailed description of what you have as far as pressure switches, etc and you can rework the stock wiring.
Theres a very small chance it might be factory wired to automatically lock in 4th, you need to drop the pan and see. Then supply 12 volts to the right pin.
Old 05-07-2009, 10:00 PM
Jmreaper's Avatar
if i took pictures of it would u be able to tell me and wat kind of pics do i need to take
Old 05-07-2009, 11:51 PM
Yes, pics of the valve body and where each wire terminates.
Quick Reply: can a 700r4 be converted to a vss
