GOT MY NEW TRANY TR6060 (T56 Magnum)
Old 05-05-2009, 03:19 PM
Big_Bird_WS6's Avatar
Default GOT MY NEW TRANY TR6060 (T56 Magnum)
got my new trany in. it is bad ***. i got it from D&D. great guys. only problem is that i think there was a misunderstanding when i ordered it. i wanted a 2.66 first gear. and i got a 2.97 first gear. but the great guys at D&D are sending me a new one with 2.66 gears. and then i am sending mine back.
Attached Thumbnails GOT MY NEW TRANY TR6060 (T56 Magnum)-tr6060-2.jpg   GOT MY NEW TRANY TR6060 (T56 Magnum)-tr6060.jpg   GOT MY NEW TRANY TR6060 (T56 Magnum)-tr606-1.jpg
Old 05-05-2009, 03:31 PM
Kleeborp the Moderator™
MeentSS02's Avatar
What mods have to be done to fit this in an F-body?
Old 05-05-2009, 03:32 PM
ATLSS's Avatar
Very nice.
Do you mind pulling the rubber boot up and telling us if they us a shifter with stops?
Old 05-05-2009, 04:03 PM
^^^ first to Meentss02. no mods need to be done. tremic sells a direct replacement trany for out cars.
^^^ second to atlss. i pulled boot and there was no stops on the shifter. idk if there is any built into it. i do know that i will proble either wait for someone to release one. or make my own.
Old 05-05-2009, 06:23 PM
bearcatt's Avatar
That is a cool looking transmission.
I just spent alot on my MN12.
But I still feel like getting one too. hahaha
What can I pick one up for ?
Old 05-05-2009, 07:56 PM
thesource's Avatar
Is that unit suppose to be a direct fit for an F body?
Old 05-05-2009, 08:10 PM
chuckyt1's Avatar
Looks kind of long behind the shifter? Do you need to shorten the ds?
Old 05-05-2009, 08:47 PM
thesource's Avatar
Its a lot longer than the F body T56. Its also got a larger output shaft so a new yoke is required as well.
Old 05-05-2009, 09:13 PM
price aroun 2800 i think. idk i get a discount.
it looks longer but about the same size. it is just the shifter is moved forward about 1 1/2"
and yes it has a 31 spline output.
Old 05-06-2009, 07:53 AM
thesource's Avatar
It looks longer because it is longer. The main case is the same length as the T56. That tailhousing is at least 2" longer than an F body tailhousing.
Old 05-06-2009, 10:17 AM
VIPRETR2's Avatar
Does that mean the shifter placement is the same as a stock T-56? Just curious since Big Bird posted the shifter was moved forward. Thanks,
Larry
Old 05-06-2009, 10:22 AM
bearcatt's Avatar
Does the new " T56 Magnum " lol, require a shorter drive shaft or any other modifications?
Besides the 31 spine yoke.
Two more inches ... I would definetly have to remove the Y-pipe to get one of those
TR6060s in there.
Old 05-06-2009, 10:47 AM
thesource's Avatar
Larry
From what I was told by our Tremec rep, they designed it to be able to flip the shifter 180 degree to place it more foward or backwards if needed. Does this one of those locations is the stock F body location? I am not sure because we have not received any units yet. They keep telling us they are coming.
TR6060s in there.
I would imagine it could pose an issue depending on the exhaust setup in the car. Once the units start to really hit the market, we will all know pretty quickly whats needed to make them work.
Old 05-06-2009, 11:29 AM
bearcatt's Avatar
True on the exhaust setup.
It will be interesting... I think Big_Bird will be the first one on here to
install one of these on an F-body. It won't be too long before we get
some feedback.
I'm also curious to see exactly what's inside of these transmissions.
It will be nice if and when parts and/or service manuals become available.
Old 05-06-2009, 12:17 PM
first. yes it does flip around. but in the picture it is in its furthest back postion.
second. the stock t-56 for main shaft tip to end it 31.9". the t-56 magnum is 33.6". so yes there is a 1.7" difference.
third the shifter on the t-56 is 29.4" from tip of main shaft. on the magnum it is 26.6 in the farthest back location. which is a difference of 2.8". now tremic has told me time and time again it will not mess up the fit of the car. but it will move it further forward. this is why i said i will probly make my own shifter so i can move it back.
any more questions let me know i got the 2009 tremic catalog right in front of me.
and bearcatt, you asked what is in the inside. i heard it was touch by gods hands. but they rate this trany to 700 lb-ft. and i hope to make that and then some. so we will see how long they last. i got a year to break it.
Old 05-06-2009, 03:28 PM
thesource's Avatar
It wasn't God, it was a mexican name Jesus and he works for Tremec in the plant down in Mexico.
Basically the TR6060/T56 Magnum is a little stronger than a T56 and pretty much on par with what came in the Viper when it had a T56 still.
Old 05-06-2009, 04:15 PM
source i would agree that is is made in mexico. i hope i dont get the flu (cough cough)
but the gears are twice as big, the hole trany is better. and for it to be rated at 700 lb-ft which is twice the normal t-56. something had to change.
Old 05-06-2009, 04:33 PM
thesource's Avatar
How can the gears be twice as big yet the unit only grows 2" in lenght and remains the same size up and down? The distance from the front plate to where the tail housing bolts on is the same length as a T56. That is the area where 1-4 gears are located. The only reason the unit is 2" longer is because of the way they designed the tail housing. The last 6"-7" of the unit is nothing but hollow space other than the speedo gear or reluctor wheel.
How many stock T56 units fail at 450 lbs of torque? How many have taken 600+ lbs of torque with a stock main shaft and input shaft? How many Vipers are putting down 1000+ rwhp on a basically stock T56?
Tremec rated the T56 very low to be on the safe side of things. This was done in the GM units mainly because of the 27 spline output shaft. The Ford units were rated around the same because of the 10 spline input shaft and 27 spline output shaft when talking about the 03-04 Cobra.
Its all in the marketing. I hope the T56 Magnum is a hit so the prices come down on the regular T56 as well as what cores cost to purchase. $500-600 for a core is a little ridiculous in my opinion yet thats what they bring most of the time.
Old 05-06-2009, 04:50 PM
BIG_MIKE2005's Avatar
Sounds like a way better option is to have the stock T56 rebuilt by Tick performance then since the other shop went under. Then there is no guessing on weather or not it fits. And the rebuilds have been working for many years now on some of the fastest LS cars in the nation.
It'll be interesting to see how many people have fitment issues with these since there isn't alot of solid info yet. I'll sit back & watch for now to see how it goes.
Old 05-06-2009, 05:21 PM
thesource's Avatar
I just did a LS1 T56 with upgraded billet keys, bronze fork pads, iron 3-4 shift fork, machined Viper input shaft and Viper output shaft for a local customer. The bill came in at just under $2100 (core was provided) and I would put it against any TR6060/T56 Magnum out there.
I'm not saying the T56 Magnum is junk but its not much superior to the T56 IMO. If you need a unit and do not have a core, its a good option to consider. If you have a good core to work with, having it rebuilt is a better choice IMO.
Quick Reply: GOT MY NEW TRANY TR6060 (T56 Magnum)
