Oil dipstick showing low?
Old 05-05-2009, 05:26 PM
SoxXpupPeT's Avatar
Default Oil dipstick showing low?
i just rebuilt my engine and put the dipstick back in and filled my engine up with 5 quarts but for some reason my dipstick shows that its 2 quarts low. does anyone have any suggestions ? the dipstick tube is fully into the block, bolted and siliconed up.
Old 05-05-2009, 05:29 PM
ss.slp.ls1's Avatar
Stupid question...you are reading it with the car off and parked on a level surface correct?
Old 05-05-2009, 05:40 PM
4THGENCAMAROFAN's Avatar
Not a stupid questions at all....that's the problem most people run into is leaving the car off.
Old 05-05-2009, 05:44 PM
djjab57's Avatar
car is supposed to be off when checking the oil
Old 05-05-2009, 05:48 PM
ss.slp.ls1's Avatar
^Yes.
Old 05-05-2009, 05:50 PM
SoxXpupPeT's Avatar
car is off. and yes its on a level ground. i checked it before and after i ran it and the level did not change.
Old 05-05-2009, 05:51 PM
MTBSully's Avatar
i would like to know as well. mine always reads high :/
Old 05-05-2009, 05:58 PM
djjab57's Avatar
Originally Posted by ss.slp.ls1
^Yes.
i wasnt asking i was telling lol
Old 05-05-2009, 06:04 PM
ss.slp.ls1's Avatar
I wasn't answering I was agreeing.
Old 05-05-2009, 06:06 PM
My95Z's Avatar
Was this on the first startup type deal? Think about it, when you do oil changes oil will still remain in the passageways and lifter valley and what not. Why you are adding oil after a rebuild it will have to make its way through all the engine. Also it will use some oil during break in its normal.
Old 05-05-2009, 06:09 PM
ss.slp.ls1's Avatar
Not to mention, if you just added the oil, you have to run the engine to fill up the filter. But that would make it read high, not low.
Old 05-05-2009, 06:17 PM
SoxXpupPeT's Avatar
i know this. i had put 1 quart in the filter and 4.25 quarts in the engine over the rockers and lifters when i was putting it back together. i ran it for at least 20 minutes yesterday and it says that its still 2 quarts low
Old 05-05-2009, 06:32 PM
djjab57's Avatar
just throwing this out there, but did you use the same stock pan?
Old 05-05-2009, 06:55 PM
FASHOOTER's Avatar
Did you have dipstick housing out when you did rebuild? Maybe it didn't get pushed all the way in block.
Old 05-05-2009, 07:06 PM
SoxXpupPeT's Avatar
yes
yes
Old 05-05-2009, 10:37 PM
SoxXpupPeT's Avatar
bump. anyone else have any suggestions ?
Old 05-06-2009, 12:26 PM
kinglt-1's Avatar
LS1Tech 10 Year
Was the pan put back together with the stock windage tray and baffle? I read in one of your other threads that you were contemplating leaving one out because of fitment issues.
Old 05-06-2009, 01:10 PM
fergymoto's Avatar
Just fill the thing up to the proper level and keep an eye on it.
Old 05-06-2009, 04:12 PM
SoxXpupPeT's Avatar
i had put in a windage tray. there were no fitment issues. there was just no windage tray to begin with. but it still shows low.
i would like to do that but i know for a FACT that i have 5.25 quarts in there. and i dont want to over fill the engine. that wouldnt be such a good thing to do
Old 05-06-2009, 04:21 PM
fergymoto's Avatar
You started out with a bone dry engine. It could very well take 6 quarts. What makes you sure you need two quarts instead of a half quart or one quart? A half quart will raise the oil level on the dipstick considerably.
Quick Reply: Oil dipstick showing low?
