Quick Question - replace head bolts or not?
Old 05-06-2009, 08:38 PM
NateLS1's Avatar
Default Quick Question - replace head bolts or not?
Trying to get info on replacing head gaskets on a 1994 LT1 Camaro.
I found the cylinder head gasket kit from Thunder Racing so far..
Do I need to replace the cylinder head bolts or not?
And what type of sealant is needed on the bolts before they go back in? Found a GM part number, but it didn't describe exactly what it was.
Thanks!
Old 05-06-2009, 10:05 PM
shbox's Avatar
I would replace the bolts with some ARPs. Permatex hi-temp thread sealant is what I use. You can get it at most parts stores.
Old 05-06-2009, 10:08 PM
AChotrod's Avatar
If I have ARPs do I need to replace them next time the heads come off? Or thats only for factory bolts?
Old 05-06-2009, 10:57 PM
shbox's Avatar
The ARPs are good for numerous uses. Factory, non-TTY bolts would be questionable, but not necessarily unusable. I like to err on the side of caution for something that important.
Old 05-06-2009, 11:30 PM
RamAir95TA's Avatar
TTY bolts can NOT be reused.
Old 05-06-2009, 11:39 PM
SoxXpupPeT's Avatar
yes arp or bust
Old 05-07-2009, 07:37 AM
shbox's Avatar
Never said they could.
Old 05-07-2009, 09:26 AM
RamAir95TA's Avatar
I never said you didn't say. Just wanted to clarify.
Old 05-07-2009, 09:39 AM
Village Troll
SS RRR's Avatar
I've had the same set of ARP head bolts for at least 5 years now. I think my top end has come off at least once a year and now they are on my 396. What's beautiful about them is they cost about the same as stock TTY bolts...
Old 05-07-2009, 10:18 AM
Elliott's94Z's Avatar
ARP'S here too..
Quick Reply: Quick Question - replace head bolts or not?
