Mileage on Cam Bearings
Old 05-08-2009, 04:30 PM
Camaro-BMF's Avatar
Default Mileage on Cam Bearings
hey guys i just put a cam an heads, Does anybody know at what mileage do the cam bearings wear out?
Old 05-08-2009, 04:57 PM
SoxXpupPeT's Avatar
at 155k miles mine were completely gone. id figure around 120-130 is when theyll wear out
Old 05-08-2009, 05:00 PM
Elliott's94Z's Avatar
Ha...well one of mine was gaffle blasted (my term for F-Up) and my motor only had 72k. If you can get access to them change them out.
Old 05-08-2009, 05:15 PM
ss.slp.ls1's Avatar
Pull out the old cam and inspect the cam bearings. If they are shot, replacing them requires dropping the motor.
Old 05-08-2009, 09:29 PM
My95Z's Avatar
It really depends how well maintained, how hard your car was driven, what type of cam and spring pressures you were running with, and if the cam swap was ever done if they got nicked.
Mine looked good at 140k when I rebuilt, but the car was 100% factory so idk.
Old 05-08-2009, 09:42 PM
blake110106's Avatar
my front bearing looks great right now 127K. Have yet to check the rest tho.
Old 05-08-2009, 09:47 PM
My95Z's Avatar
Normally the front bearing will wear first/the most b/c it has the most load on it.
Old 05-08-2009, 11:16 PM
saylorZ28's Avatar
not to high jack but what would a bad cam bearing look like and to change them out does it require dropping the crank is it a hard thing to do or does it require a machine shop?
Old 05-09-2009, 09:35 AM
My95Z's Avatar
A bad cam bearing will be severely with either groves, gouges, be out of round, or discoloration. To pull them out the crank really needs to come out so you can see what you're doing and to drop the bearings in and hook them to the tool. They sell a cam bearing drive tool that you really need to have to install them, if you don't have one it needs to go to the machine shop. Also a spun cam bearing could have possibly trashed the block and at very least will need to have the cam journals line honed.
Old 05-09-2009, 09:45 AM
saylorZ28's Avatar
by discoloration do you mean a bronze color or burn like metal to metal contact
Old 05-09-2009, 10:11 AM
trippinholyman's Avatar
burn like metal to metal, ,grooves etc
ie here http://home.comcast.net/~rebel1608/cam-bear.JPG
Old 05-10-2009, 12:45 PM
saylorZ28's Avatar
what if they are completly bronze
Old 05-10-2009, 03:40 PM
My95Z's Avatar
Like copper colored? If they ate all the way down to the copper level, yeah they're shot, but I don't think LT1's came from the factory with any copper/lead bearings I thought they were all aluminum...
Old 05-10-2009, 03:48 PM
Mine were still nice and shiny w/ 75k just that the front one had a chip out of it.
Old 05-10-2009, 05:11 PM
saylorZ28's Avatar
no these are copper bronz lookiin thats why i haen't put my nw motor in yet ... i am wondering if i can pull the crank and freshn up the botttom end and change the cam bearings without pullin the pistons
Old 05-10-2009, 05:26 PM
My95Z's Avatar
You should be able to, as long as you can drop the cam bearings in and hook them to the tool you should be ok.
Old 05-11-2009, 11:36 AM
ss.slp.ls1's Avatar
What exactly do you mean by freshen up the bottom end? If you are thinking about doing what I think you are, you might as well drop the motor and do a full rebuild...you can't simply pull the crank and install new main and rod bearings, you need to get the block machined.
Old 05-11-2009, 04:15 PM
moderate Z28's Avatar
When I pulled my stock cam out, it was very bronze colored on all the lobes. It looked kinda burnt. Does that tell me anything?
Old 05-11-2009, 05:19 PM
ss.slp.ls1's Avatar
Pics? Some wear is normal.
Old 05-11-2009, 05:35 PM
Its in the attic now I believe. I'll try to get some pics.
Quick Reply: Mileage on Cam Bearings
