strip rims????
Old 05-10-2009, 06:45 PM
franksaltz28's Avatar
Default strip rims????
Im looking for a set of rims that i can just swap out with my rims when i get to the track. I want some 15 inch rims that are 8-9 inches wide. are there any rims i could put some mt et drags on and just swap out without doing any fender work.
Old 05-10-2009, 09:35 PM
Red93z28's Avatar
yeah draglites or prostars, 15x8's in the back, just might have to do a little caliper grinding from what i hear, but it takes about 2 minutes, if you dont feel like buying the welds, u can get the jegs or summit brand
Old 05-10-2009, 09:38 PM
01z
01z's Avatar
lmao at 2 minutes, i just pust some draglites on my car......after 3 hours of grinding
Old 05-10-2009, 09:44 PM
Red93z28's Avatar
well tons of people have no problems with 15x8's or even 10's, do u have a different break setup
Old 05-10-2009, 09:56 PM
01z
01z's Avatar
stock brakes, had to grind the **** out of them for some 15x8s
Old 05-10-2009, 09:57 PM
01z
01z's Avatar
i think the lt1 brakes are different, so maybe it wouldnt take you that long
Old 05-11-2009, 12:25 PM
Red93z28's Avatar
yeah they are they dont need alot of shaving basically just on the fins of the caliper
Old 05-11-2009, 01:35 PM
ok grinding the rotors wont effect the cars braking in any way will it?
Old 05-11-2009, 01:51 PM
01z
01z's Avatar
no, you are just making clearance
Old 05-11-2009, 02:11 PM
STEEPSS's Avatar
+1 for grinding. my 15x10 prostars took about an hour per side of grinding to make fit.
Old 05-11-2009, 06:17 PM
Camaro396's Avatar
Took me about 30 seconds per side with an angle grinder to clear for my 15x10 prostars, now I run 15x10s that fit over stock brakes.
Old 05-11-2009, 06:42 PM
what rims do you have that fit ofer stock brakes? i would like to do as little as possible, but if i need to do some grinding i will.
Old 05-11-2009, 08:17 PM
Camaro396's Avatar
Weld Racing R/T wheels. Designed to clear stock LS1 brakes.
