Anyone With A HSW Trans Tunnel Bracket Please Read.
I just finished installing the bracket on my 01 Camaro. I went to go start the car, it cranked but wouldn't start. No fuel pressure and the fuel pump fuse was popped.
I removed the bracket, seat cushions and seat back, peeled back the carpet on both sides and found that the fuel pump harness runs directly where the bracket mounts(on the driverside.) Luckily I did not drill through the wires but only pinched them. So I rerouted the wires to the where the seat cushion bottom is, out of the way of the bracket mounting points and seat belt latch.
I did a search but came up with nothing in terms of anyone else having this problem and the instructions say nothing about a harness there or having to lift the carpet. I'm not knocking the product or HSW at all, it's top notch stuff and they've helped me a ton. But I suggest for anyone who has the brackets installed or is planning on installing it, take a little extra time to remove the driverside carpet and move the harness out of the way.
Hell, they developed it, so they know its there.
Why should it be his responsibility? I've never really had any experience with HSW so I'm not bad mouthing them, but I really think that something like that should be included in the instructions. I was about to drill into my floorboard to mount some blowdown tubes and mount my nitrous line, and if it wouldn't of been for my buddy, who is a GM tech, I would have most likely drilled right through the wires. Now, something like that would have been my fault. But to buy a product from a major company, like HSW, I think it would be smart of them to include a note that mentions your fuel harness under the carpet. It would be a good way to cover their own ***.
i work at a dealer and we get blamed all the time for people who let their State inspection expire...its our fault cause we didnt let them know they needed inspection on their vehicle. are ya freakin kidding me???? not exactly the same but its the same principle to make my point.
im not tryin to pick a fight with you but it isnt HSW's fault this happened just as its not Procharger's fault that someone blows their engine when using their product. the OP was just posting up information that may or may not be known to prevent future issues with the same product, which i may add, isnt the only one on the market that mounts in the same location.( like he mentioned in post #2)
uhmm b/c its HIS vehicle?!?!? c'mon now....people just need to start takin responsibility for their own actions and stop blaming someone else. its your vehicle. Common sense would tell you not to drill through a carpet without knowing whats on the other side. anyone thats ever worked on a car with half a brain should know this. (no disrespect to the OP).
Again, I totally agree and trust me, I was kicking myself when it happened. I am always cautious and careful when I work on customers cars and especially my own car.
I was hesitant to post this because I was worried it would be read the wrong way. I posted this only to try and prevent this problem from happening to other people, not to point the finger at anyone.
