12:1 370ci idle vid
car sounds really good man. care to share any details on the build such as who built it, how much you have into it, and parts used? i'm thinking of starting a 370 build so any info would be cool
-'99 LQ4 block
-LS6 crank
-Scat I-beam 6.125" rods, ARP hardware
-Mahle forged/coated 4.030" pistons, 4cc reliefs
-Clevite coated main/rod bearings
-custom cam
-PRC 5.3 stg 2.5 heads milled to 57cc, mild hand cleanup work done, LS2 MLS gasket
-7.375" chromoly pushrods, stock rockers
-ported fast 92, PTM 92mm throttlebody
-custom DP nitrous system
-pacesetter headers, 3" duals w/flowmaster 1 chambers
Notable clearances/measurements:
mains- .002"-.0025"
rods- .002"-.0025"
rod side clearance- .023"
crankshaft endplay- .005"
deck height- .013" above deck
ring gaps- .024" top, .028" second
compression- 12:1 SCR, 8.7:1 DCR
Car has built t56, spec 3 clutch, strange 3" chromoly shaft, moser 9" w/4.30's, wolfe 6pt etc etc. Haven't had it to the scales yet, but it's gotta be one heavy bitch. Here's a couple pics:
Not yet, just fired for the first time on Monday. Going to get some break-in miles on it and some street tuning done, then head to dyno and track.
