Advanced Induction Heads and Cam 383 New Setup
Hey, I'm kind of new here. Just put together a new set up and fired it up for my 95 Z-28, let me know what you think. I had a 355 with trick flows and an AI Hydraulic Roller Cam and was going 11.40 @ 121 but time for a bit more.
New Engine--
Howards Billet Main Caps; Callies Magnum 3.75 Crank; Oliver 6" Billet Rods; SRP Pro Series 4.04 13.2:1 Pistons; Canton Oil Pan; Advanced Induction 215cc CNC Trick Flow Heads with Solid Roller PSI Springs, Xceldyne Titanium Retainers and Locks and Hollow Ferrera Valves; Advanced Induction Solid Roller Cam 25x/26x @ .050, .7xx lift; Morel HIPPO Solid Rollers; Jesel 1.6 Shaft Rockers; Ported Stock Intake Manifold; 48lb/hr Trick Flows; Twin 58mm Holley TB; FAST XFI wired in conjunction with the stock computer.
Here are some pics of the build;
The Advanced Induction Heads look awesome!!!
I will post some short block pics later.
Here is a video of the car idle with open exhaust:
http://www.youtube.com/watch?v=36KiV7FCQCw
Track this weekend for some testing; I'll post some times and video when I get home.
New Engine--
