Quarter mile times with 228r cam?
Alright so by next week my car should be finished...knock on wood. Anyways, after a tune, what would you guys say a good time to aim for is? This will be on mickey Thompson drag radials btw, I was hoping with a tune, cam only, I could get into low 12s with a cam only setup. I've never seen a 228r cammed car run at the track before, so im not sure how the mid range cams like this one do but ya..just curious
i have a 226/226 and i went 12.1 that was with a 1.7 60ft and full weight. youll hit that no problem. after i pull weight and get the 60ft down i should be 11.9s. let us know how it goes im looking to step up a little bit soon i think
I didnt make it to the track this weekend like I planned. Once again it rained on Friday so that automatically closes the track the following day. I had a lot of work to do anyway so I probably wouldnt have made it. Wanted to go Sunday but had other things to do that were more important. I will run the car this weekend providing it doesnt rain.
LSX Mechanic
The cam has less to do with 1/4 times than almost anything else. The entire setup of the car determines how fast it will get down the track, not a cam by itself.
I've seen 224 cams go 11.50's, and I've seen 240 duration cams go 12.20's. And vise versa. The setup of the vehicle will determine how well the cam performs.
Truck here with race weight of 3944! Went 11.92 @ 113 spinning very badly.
LS1 - 228r/112 - Home ported LS6 heads milled .010 - .040 cometics - Ported Fast 90 - LS2 TB - UD pulley - Custom 4" ram air - Volant CAI - Pacesetter LT's - TCI competition 3800 - 4.10 gears - (worn out) MT ET STREETS 28x11.5x16
Next visit at the track will be with everything listed except a change in gears and tires. Going to MT ET DRAG 29.5x10.5x15S and 4.56's.
