pilot bearing removal
Old 05-15-2009, 12:51 PM
96Formula6spd's Avatar
Default pilot bearing removal
anybody know any trick on how to remove these. The grease idea is not working due to the fact that my bearing is bent out of shape and nothing has a tight grip around it. Any ideas?
Old 05-15-2009, 12:56 PM
camar0corey's Avatar
I use the wet toilet paper method, I keep packing wet toilet paper behind it and then keep tapping on the paper with a ratchet extension and a hammer, it eventually comes out, its a pain in the ***.
Old 05-15-2009, 02:21 PM
ClovisAutoMotion's Avatar
you could always go rent or borrow the tool
Old 05-15-2009, 02:48 PM
BALLSS's Avatar
harbor Freight has a blind hole bearing puller cheap
Old 05-15-2009, 04:14 PM
97pontta's Avatar
If you have a 5/8-11 tap or know some one who does it works well. I used the tap to put threads in the bushing and a 5/8 bolt to push the bushing out by screwing in the bolt until it bottoms out it will push the bushing out. If your bushing has a lot of wear you would have to go to a bigger tap. I used this method on mine just a few weeks ago and the bushing came out super easy.
Its probaly not worth buying a tap just for this if you don't already have one though.
Old 05-15-2009, 04:40 PM
ss.slp.ls1's Avatar
Just get the loaner pilot bearing removal tool attachment and slide hammer from Autozone. That's what I did.
Old 05-15-2009, 05:01 PM
SoxXpupPeT's Avatar
rent one of those and make your life very easy
Old 05-15-2009, 05:09 PM
collier341's Avatar
the tool didn't seem to work when i did mine.. i had to chisel mine until the bushing actually crumbled..
Old 05-16-2009, 06:37 AM
Wicked94Z's Avatar
as mentioned above.... toilet paper method works great
Old 05-16-2009, 09:59 AM
xx_ED_xx's Avatar
IF it is a pita bearing I usually just drill a couple of holes in it and break it
Old 05-16-2009, 11:36 AM
speed_demon24's Avatar
Hammer and chisel worked for me. It wouldn't budge with the tool.
Old 05-16-2009, 04:20 PM
went to autozone and rented a tool got it our in 2 mins.
Old 05-18-2009, 11:15 AM
ss.slp.ls1's Avatar
Yep, that's what everyone should do. I don't see any pilot bearing trumping a big slide hammer.
Quick Reply: pilot bearing removal
