11 Second Club Snake eyes are a good thing
Track results..11 second club
Old 05-15-2009, 10:36 PM
z28241's Avatar
Default Track results..11 second club
Heres a pic of two of my time slips tonite from NYIRP.car #58 on the right.First real runs for me on the new H/C swap..11.919 on left time slip, on the left slip, a 11.95 pass i actually spun a little, so I know theres more!..3.42's held me back a little. Everything else is in sig..CHECK FOR UPDATE DOWN A FEW>>
Old 05-15-2009, 11:13 PM
z28241's Avatar
Talking
The time slip on the left was against a 650 hp Cobra bla bla bla..
I tried uploading the vid and wont go thru..11.90 (his)
Old 05-18-2009, 06:30 AM
Mac 2002 SS's Avatar
congrats on the new best, man. it seems that you do need a 3.73 or even a 4.10 to stay within the powerband of that "MONSTER" cam you got . i do belive once thats done and a little more fine tuning ,you should be in the low to mid 11's .
Old 06-04-2009, 01:07 AM
z28241's Avatar
UPDATE..Went to the track on sunday, better prep and Mike @ New Era played a little more with the tune and I ran consistant 11.82's @ 116xxmph..I have 4.10's in the works and will post new results..
Old 06-04-2009, 09:56 PM
Good job. thats all it takes is a little fine tuning to dial her in . i'm hoping to run Friday nite myself ,but with all this rain in the area , i just might have to wait til next week.
Old 06-10-2009, 03:38 PM
PewterScreaminMach's Avatar
Nice job! I read your first post and was about to say your trap looked a few mph low for that power and H/C/drivetrain combo but then I saw your update post and it looks dead on! People underestimate what a proper tune can do, especially with those bigger cams.
Old 07-16-2009, 12:05 AM
z28241's Avatar
Another update, went 4.10s, with exactly NO change in nothing!! everywhere on time slip is the same..
Old 07-16-2009, 12:25 AM
denice25's Avatar
nice job..thanks for the update!
Old 07-25-2009, 10:57 AM
hhmmm......what rpm are you shifting at ? with that cam ,i would think 6700 at least .
Old 07-25-2009, 06:21 PM
MRZ28's Avatar
Are you sure you didnt spin any??
Old 07-25-2009, 06:26 PM
MRZ28's Avatar
What was your 60ft with the 410s? if your not cutting at least a low 1.6 with your setup, you have got to be spinning, or there is another problem....
Old 07-26-2009, 09:06 PM
TA1364's Avatar
I agree, low 1.6s should be no problem with that power.
Btw Mrz28 Ive heard about your car and would like to check it out sometime. Im considering doing an ms3. Op sorry for the thread jack!
Old 07-27-2009, 07:22 PM
z28241's Avatar
Ya I thought so too.. im doing low 1.70's sixty foot, my brother filmed my runs, dont look like shes spinning..3 passes btw
Old 07-27-2009, 07:26 PM
z28241's Avatar
6600 rpm
Old 07-27-2009, 11:44 PM
MRZ28's Avatar
What was the MPH on those runs? the same?
Old 07-27-2009, 11:46 PM
MRZ28's Avatar
That 60ft is still a little weak for your setup too.
Old 07-28-2009, 10:50 PM
z28241's Avatar
Ya i agree, im gonna have my brother film from a better location, to see if i am spinning, i'm sure its not alot, but maybe ITS NOT a dead hook..went to new era today,my guys up their think the same. mike raised a couple of shift points and recalibrated my speedo.. i've been on the fence for a while about going to 15 inch rims and taller slick type tire ya know to get that snap out of the hole, I just liked the "sleeper" look with stock rims and dr's. Im going to go to track tomorrow if weather holds and/or friday..let u guys know..Not for nothing, My converter has a low 1.69 str..think it might be lil tight..
Old 07-29-2009, 05:50 AM
before you go to the track, remove your front sway bar ,unless you have already done that too. and you may want to try a LT.Weight battery ,too. both can help lose a few pounds up front without losing your stock look and hopefully help your 60ft's out a little.
Old 07-29-2009, 12:04 PM
z28241's Avatar
I took sway bar off before last track outing..
Old 07-30-2009, 09:27 AM
Intercooler2's Avatar
On good tires? Seems kind of lagging vs some of the bolt-on cars... for heads/cam setup.
Quick Reply: Track results..11 second club
