hotcam on a factory stall?
Old 05-17-2009, 04:28 PM
dameter21's Avatar
Question hotcam on a factory stall?
Do you guys think I might get by by installing a hotcam and running with the factory stall convertor until I can afford a new bigger stall.
2000 TA A4, longtubes/ory, lid, slp pulley,
Old 05-17-2009, 04:47 PM
tpain's Avatar
you will get about 20 different anwsers on this, but im running the hotcam with the stock stall with a mail order tune and it drives almost factory. i have a stall just havent installed it yet.
Old 05-17-2009, 05:19 PM
formulaon18s's Avatar
As a former auto owner I would reccomend stall first, for two reasons. One you will get better track gains and drivability with the stall even with stock cam and two the stock stall with make the cam aggrevating at times.
I did the cam first and wished I went the other way after all said and done. Gained .7 seconds and 7 mph with hot cam kit and headers, .8 seconds and 2mph with the Vig 3000. Not that it makes a big diff but this was on an LT1.
Old 05-17-2009, 08:09 PM
dameter21's Avatar
thanks guys
Old 05-17-2009, 08:39 PM
LCplmarine98's Avatar
Your sig says you have a 4400 stall? IF thats the case go big cam.
Old 05-18-2009, 12:27 PM
topher455's Avatar
The hot cam will run 1800 in sixth on a m6 car so your stock stall will be fine. That cam makes good power and torque right off idle. It is not right for a 4400 stall though. Either change the cam or the stall IMO.
Old 05-18-2009, 10:23 PM
dameter21's Avatar
my sig is old I never changed it I had a big stall with a cooler and it burned up my factory trans,.
Old 05-18-2009, 10:41 PM
ss69's Avatar
Will be no problem
Old 05-19-2009, 07:22 AM
topher455's Avatar
Gotcha. The only other thing I can say about the hot cam is that I have heard it is hard to tune. I only ran it in a carbed application so I dont know.
