VSS Question...
Old 05-18-2009, 04:17 AM
7071's Avatar
Default VSS Question...
Is VSS signal different between Corvette C5 and Camaro? Don't both use 40 tooth wheel for driveshaft revs, or is signal from C5 after rearend gears, so ratio should be further modified?
2002 corvette fly-by-wire LS1 bolted to 4L60E swap into chevelle.
PCM was flashed with 02 Corvette program, modded for rear end ratio (3.31) and tire size (26.7).
PCM reports car it doing 150+ MPH when only going about 20, so motor shuts down.
Old 05-18-2009, 10:13 PM
7071's Avatar
anybody?
Old 05-19-2009, 05:30 AM
rsz288's Avatar
If C5 is like C6 and my memory is up to scratch, the reluctor is on the ring gear in the diff/transaxle.
Quick Reply: VSS Question...
