Zombie made a boo boo and put e85 in his tank
Old 05-23-2009, 02:06 AM
Zombie's Avatar
Default Zombie made a boo boo and put e85 in his tank
Ok, so it wasn't really a boo boo, I was feeling frisky and the hooker never showed up so I had to do something exciting.
Been wanting to try this. Ran the tank down to "oh crap I'm gonna need to call AAA levels" and then added 6 gallons of E85. Took the fuel map in Mega Squirt II (MS2) and multiplied my fuel map by 1.3. An that's about it. Car was a little rich because there was probably .5-1 gallon left of 91. Started driving around on 6psi and the lambda looked good .90-.93 at cruise and .70 at WOT. Since things looked good I drove to another E85 station and added another 5 gallons. This leaned out the mixture to just about perfect. Tried upping the boost more but I could only spike 14psi and then fall back to 12 since the spring is so weak. Got a 14psi spring to install hopefully tomorrow. For the little bit it held 14psi I was able to see the injectors were on for 17mS which would put me at 100% DC @ 7000 rpms. I'll have more fuel info once I get the new spring in.
Observations:
Exhaust note of the car changed, spool felt like it might be a little faster but I don't know. Ran my 100 Octane timing which has 3 degrees more timing (17 at 5200 rpms peak torque and 22 by 7000 rpms) than my 91 octane tune. That seemed to wake the car up and improve the idle. Need to put it on the dyno to find out where the best timing is.
1.99/gallon woot!
Fuel system is stock lines, stock rails, still returnless, dual walbro 255's and 95lb/hr injectors. Don't know how far I can push this setup, but I'll find out soon enough. Injectors are pretty much done is my guess, but I'll buy some 120lb/hr ones to see how far the dual pumps will take me.
Old 05-23-2009, 03:20 AM
Avengeance's Avatar
Interesting!
Old 05-23-2009, 09:06 AM
smokinHawk's Avatar
what is your best trap then or HP level?
Old 05-23-2009, 09:45 AM
Zombie's Avatar
My best trap on 100 octane is 136.6 MPH, why do you ask?
Old 05-23-2009, 10:23 AM
t-1
t-1's Avatar
more fuel burning means more exhaust ,it should be spooling faster.
Old 05-23-2009, 11:23 AM
Zombie's Avatar
yup, but I don't trust my butt dyno, it's not very sensative. I need large changes to be able to tell if there is a difference. PUt the 15psi spring in the gate this morning so that should make it spool faster too since the old spring was only holding 6psi.
Old 05-23-2009, 12:51 PM
one fast zo6's Avatar
guys have made 820 at the tire with 96lb injectors and E85 fuel.
Old 05-23-2009, 12:58 PM
TS6
TS6's Avatar
Dyno don't mean ****. He has a TH400, he could dyno 650 RWHP and be making more crank HP than a guy making 820 with a 6 speed.
Old 05-23-2009, 02:59 PM
Zombie's Avatar
I officially a mechanic now, I'm in 1320's garage on the laptop looking up torque specs. Three guys wrenching and me surfing, I'm just the nerd of the group.
So an update on the car. New WG spring is in and is 12psi on the gate. Upped the boost to 15psi and added 5 degrees of timing. I'm running 19 degrees at peak torque and then up to 24 by 7000 rpms. Injectors are running around 88% DC at this level. We took the Undead Sled out as a parts runner to get hoses and fittings since 1320 is in process of turboing a 04 Chevy H1500 5.3L AWD van with a T72 turbo.
With 3 people (4200+ lbs race weight) in it and the a/c on in 90+ degree weather we started making pulls and all was good, no knock and runs very hard. Went 60 miles round trip without a hiccup and the coolant temps stayed below 220. This car rocks.
Old 05-23-2009, 03:08 PM
'Trust''s Avatar
Awesome! Coolant temps below 120??
Old 05-23-2009, 06:53 PM
98Camarod's Avatar
ECT is 120
zombie, I sent you a pm
Old 05-23-2009, 06:59 PM
Zombie's Avatar
Come on guys, I think you realized I made a typo and meant 220, geez. lol
Old 05-23-2009, 07:03 PM
98Camarod's Avatar
no way, thought it was the e85
Old 05-23-2009, 07:15 PM
Benner's Avatar
sounds like you found a good setup to run. Alot of guys with LS platforms that are moderately built are running E85 here in columbus.
Old 05-23-2009, 09:27 PM
Rickys S/C Z28's Avatar
man i wish we could get E85 around here!
Old 05-23-2009, 10:02 PM
'Trust''s Avatar
Nothing wrong with calling people out so they can embarrass and correct them selves infront of 80,000 people . J/K, I'm just jealous, e85 please!
Old 05-23-2009, 10:19 PM
ZMONSTER!'s Avatar
Ya you would think people here in California would be more into the whole e85 thing since they are a bunch of bunny humping eco *******, but alas no e85 here.
Old 05-23-2009, 10:50 PM
TS6
TS6's Avatar
I've heard that (around here anyway) the quality of E85 isn't consistent due to condensation in the tanks from lack of use. Basically the gas sits so long it goes bad, not enough people use it here. Kinda sucks, I was really considering switching.
Old 05-24-2009, 01:59 AM
1320's Avatar
Its funny, we had 4 vettes, about 5 or 6 turbo cars around the shop today but the "fun" project is the van......and we drive a 10.0 car around to get parts. We have now entered the twilight zone. And the 10.0 car is now flex fuel, and green......whats going on?
Old 05-24-2009, 02:16 AM
Zombie's Avatar
Don't forget government subsidized, doo dee doo doo, doo dee doo doo
Quick Reply: Zombie made a boo boo and put e85 in his tank
