Found a spring-lock in my oil...
Old 11-05-2003, 01:05 PM
lucky_topher's Avatar
Default Found a spring-lock in my oil...
I changed my oil last night and this came out of the drainhole... one of the semi-circle shaped locks for the valvesprings... how bad is this?
(the things called "locks" in the picture):
Old 11-05-2003, 01:08 PM
HumpinSS's Avatar
Pull your valve covers as soon as possible. You can drop a valve and trash the whole engine
Old 11-05-2003, 01:20 PM
SSean's Avatar
unless you've done a cam swap recently, recall loosing any locks?
Old 11-05-2003, 01:23 PM
Paul F's Avatar
If you've done a cam and/or spring swap lately did you happen to lose one in the process? If not DO NOT run your car anymore until you fix the problem. It will drop a valve at any time if you are missing one.
Old 11-05-2003, 01:49 PM
PlainwhiteZ28's Avatar
pull valve covers............NOW
Old 11-05-2003, 02:56 PM
Ryan23silverado's Avatar
Agreed pull the valve covers now! If you drop a valve, it will be BIG bucks and a BIG headache to fix things.
Old 11-05-2003, 03:42 PM
jrp
SN95 Director
jrp's Avatar
how was your engine running before the oil change. any ticks, thuds, or noises. obviously like the other guys said, pull the valve covers and check if a lock is missing.
Old 11-05-2003, 09:31 PM
DaleMX's Avatar
If you do find it, make sure you put that cylinder at TDC before you try to fix it or you'll loose the valve and have to pull the head.
