A body Oil Pan from Pace
Anyone used this pan on an "A" body
I have a 70 Buick GS, and I need to order a pan that doesn't have any clearance issue's
Any thought's/recommendations are appreciated
http://paceperformance.com/index.asp...&ProdID=245308
I used a stock F-body pan with no modifications...just had to move the frame mounts back. It might be different with a Buick. You may want to check out this thread if you haven't already:
https://ls1tech.com/forums/conversio...2-gm-body.html
(using the Gen I BRP mounts which is the farthest back i've seen so far)
I'm hoping you don't have steering linkage interference also.
