spindles + drag brakes
Lightest is going to be racecraft spindles for spindle mount wheels and spindle mount brakes. Cheapist is leaving them stock lol. Check out Racecraft's site. They have all the weight info listed for the different spindle/brake options they sell. Or give Brian (Madman) a call and he can get you set up with what you need.
Racecraft 3rd gen spindles and 3rd gen brakes will be lighter than just 4th gen drag brakes on stock spindles. The 3rd gen spindles/brakes will be a little more money. Brian can probably tell you the weight difference if you give him a call.
I am unable to get racecrafts website to come up and I have no idea why I am hopeing to do this at the end of the summer especialy if its save 50lbs+like I have heard. also any idea what I can ask for my bake set up for atm my pads/rotors have = miles on them and will prob have less than 2k when I go to sell them.its a 2000 trans am for reference
You should be able to get $150-200 for your ls1 brake set up if you sell it complete with the spindles.
The racecraft stuff is very nice stuff. I just ordered a set of their spindle mount spindles and strange brakes. Going off racecrafts website its a 64.2 pound savings. I needed that weight off the nose of this stock internal car were messing with. It cost a ton of money to go this route though as the spindle mount alumastars i just bought are $522 a piece now. Welds going to go out of buisness again if they keep this up.
they also have a light weight spindle that will use 3rd gen brakes and you can still use your pro stars. Its a 42.1 pound savings.
I got these, saved 57.3 lbs.
Pa Racing now has 1993-2002 Camaro 2" Drop & Stock Height Spindles. Theses spindles are TIG welded in our fixtures, using CNC and 4130 components. These spindles also offer an astounding 57.3 lbs (these are true numbers not advertising hype!) of total weight savings over stock when used with the Strange Engineering 4 Piston Drag Kit (P/N B4110WC). Also avialable in spindle mount verision with brake kit (B4597WC)
Spindle weighs as shown 6.4 lbs.
Strange Pro steel brake kit 33.5 lbs.
Pa Racing spindles and Strange brake kit 39.9 lbs.
Stock spindles and brakes 97.2 lbs.
Pa Racing vs. Stock 57.3 lbs.
