my wheels tuck in to much how to fix?
hey guys my rear wheels seem to tuck in to much.
i have a double adjustable phb so the wheels are centered.
how to i fix this and whats the cause?
OEM spec 9" or 9.5" wide wheels have around a 56 mm offset, which gives the "tucked in" look.
Way to fix:
Less Expensive: Run a hub and wheel centric spacer with longer and stronger wheel studs. Assuming they are 56 mm offset, one can add up to a 3/4" spacer to get the wheels to fill out the well.
More Expensive: Buy new wheels with a smaller numerical offset, such as ZR1's with a 38 mm offset.
Way to fix:
both would work. when my dad got his 00 ta it had the top style spacer on the back. it worked. but i have used the bottom style also. i would buy whatever is cheeper myself. but make sure u buy longer studs.
If you would PREFER the 17x11's run what ya got until you can afford them. No sense in buying spacers and installing longer studs only to toss 'em when you get the larger wheels.
