Drag Racing Tech
Framehorn Pictures.... Can I cut more???
Old 05-31-2009, 09:12 PM
landonew's Avatar
Default Framehorn Pictures.... Can I cut more???
Just did cut the frame horns.
I have a few questions before I put everything back together....
1) There is a mounting hole on each framehorn. See, on this picture of the passenger side.... it has the square demarkation around it.
On the driverside is it further back allowing me to cut off more of the horn... see, it has the same square demarkation around it.
Do I need to keep these? I can't rememeber what they mount too... If it is the bumper support then I cut deeper (especially on the passenger's side).
2) Can I cut any more of the radiator support?
The screw holes are where the airdam mounts right???? That is important for airodynamics correct?
But Taubrunit seems to have cut them off leaving very little metal.
https://ls1tech.com/forums/drag-raci...ootin-10s.html
Old 05-31-2009, 09:58 PM
3rdgen92maro's Avatar
The 5 holes in the rad support are for the air damn to bolt to. Its deff an important piece in the cooling system. The holes with the squares around them are for the factory horns to bolt to. So you really don't need them unless you plan on putting the horns back on.
Old 06-02-2009, 06:51 AM
landonew's Avatar
Thanks...
So If I cut the passengers side horn in a similar manner to the Drivers side I should be ok from a structural standpoint??
Im saw alot of people angle the cuts backward... but it seems like you could shave off an extra few pounds if you do a straight cut like I did on the drivers side. Any opinions.
Old 06-02-2009, 11:34 AM
I doubt there will be any stuructual support lost if you cut it like the drivers side. I would cut passenger side just like you did the drivers side.
Old 06-02-2009, 06:52 PM
Taubr Unit's Avatar
i havent ran a airdamn in years and have NO cooling issues at all, even with a EWP.
Old 06-02-2009, 08:39 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Here are some good pictures:
https://ls1tech.com/forums/drag-raci...-together.html
Old 06-02-2009, 10:49 PM
landonew's Avatar
More info on this please. I have heard different opinions on this.
Old 06-02-2009, 10:59 PM
TS6
TS6's Avatar
Many people have cooling issues without it, few don't. Its a 2 lb piece of plastic, keep it.
Old 06-02-2009, 11:33 PM
I would just keep it just to be safe. Like TS6 said its like 2 pounds.
Old 06-03-2009, 08:40 AM
landonew's Avatar
Alright. Ill keep it.
Old 06-03-2009, 01:32 PM
5.3LJimmy's Avatar
My car was fine driving around town without the airdam, but the first time I got on the interstate it started to overheat. From about 65MPH and up the air was not going thru the radiator.
Old 06-03-2009, 02:22 PM
landonew's Avatar
Well than its definately not worth the 2lbs
Old 06-03-2009, 03:05 PM
My thoughts exactly.
