need rims
need rims
i am looking for a used set of rims and/or rims and tires
they need to fit on a 93 z28
i would prefer that they would be the 1997 17" z28 rims or the 1998 if they fit
thanks
thanks
93-96 4th gen f-body's have a larger hub on the rear axle than on the front spindles. It is approx. 0.03" larger. This did not change until late 96 early 97 model years so wheels from 97 and later may not fit on rear of your car. Simple fix would be to lightly sand or dremel inside diameter of rear wheels if you do get any 97 or later year wheels.
