Western Members CA, AZ, NV, UT, CO, NM, HI
Where can i get German Castrol?
Old 06-02-2009, 04:26 PM
1998LS1SS's Avatar
Default Where can i get German Castrol?
anybody know where i can get a hold of it??? heard good things about it.....live in Baldwin Park.
Thanks
Old 06-02-2009, 04:30 PM
hlaalu's Avatar
haven't seen the 'german" castrol in stores for a while a now
Old 06-02-2009, 05:07 PM
djsanchez2's Avatar
From Germany Duh!
Old 06-02-2009, 05:21 PM
1998LS1SS's Avatar
Shiza!!
Old 06-02-2009, 05:28 PM
180ls1's Avatar
i have seen it at autozones but only certain ones, if not then just run pennzoil platinum
Old 06-02-2009, 05:52 PM
hitmanws6's Avatar
ws6 store has it, but its not cheap
Old 06-02-2009, 06:00 PM
1998LS1SS's Avatar
yeah i have been reading about penzoil platinum...probably going to run some sort of 40 weight....thanks
Old 06-02-2009, 06:03 PM
dilatedpeoples28's Avatar
pepboys around me had it, dunno if you have those around you though
Old 06-02-2009, 07:34 PM
MrElectric03's Avatar
Autozone in Riverside carries it.
Old 06-02-2009, 08:27 PM
Dan
Dan's Avatar
I am out myself. I am going to switch to the Pennzoil Platinum. Not sure what weight though.
Old 06-02-2009, 09:38 PM
$O$OE's Avatar
Originally Posted by djsanchez2
From Germany Duh!
word....
$O$OE's Avatar
i use pemex....
Old 06-02-2009, 10:05 PM
ZexGX's Avatar
I use WalMart SuperTech High Mileage. Then again I have a V6. It'd probably run on Canola oil. I used to run Castrol High Mileage but I discovered that if you shake the containers, the WalMart brand had a higher initial viscosity.
Old 06-02-2009, 10:20 PM
hlaalu's Avatar
omg lmao. hahaha lee im cracking up over here
Old 06-03-2009, 12:44 AM
SS4Luck's Avatar
the pep boys in anaheim hills just had it. Did my oil toinght
Old 06-03-2009, 01:38 AM
383lt1impala's Avatar
I used to run castrol 5w30. Now I'm going to run rotella t 15w40 good thing we use it on our water trucks cuz I got 5 drums of it. And I hear it has zinc and that's some sort of anti wear agent?
Old 06-03-2009, 01:40 AM
hitmanws6's Avatar
im interested to hear how castrol edge is
Old 06-03-2009, 02:36 AM
ZexGX's Avatar
Only for usually older engines with flat-tappet camshafts and lifters...
Quick Reply: Where can i get German Castrol?
