How much oil will fill the 4L80e and PY-3400 stall
Old 06-03-2009, 05:15 PM
Blade Macias's Avatar
Default How much oil will fill the 4L80e and PY-3400 stall
How much oil will it take to fill a dry 4L80e and a pro yank 3400 stall.
Old 06-03-2009, 05:56 PM
MIGHTYMOUSE's Avatar
i suggest using transmission fluid like dextron mercon and the amount depends on the pan you are using, i think i got like 14 qts in mine.
Old 06-03-2009, 08:19 PM
I got the factory pan also what did u do for a dip stick. Thx
Old 06-04-2009, 10:10 AM
ShevrolayZ28's Avatar
I'm not sure how much is in mine, it came already filled. I added a bunch more. I figure it has around 12-14 quarts in it. It's actually kind of frustrating trying to read the Lokar dipstick. I have the long one and I think fluid might be pooling in the horizontal section of the dipstick tube making the read a bit mystifying.
I'm going to empty mine back out and start over. I might even try a shorter dipstick.
Old 06-04-2009, 01:59 PM
Firechikn's Avatar
Yep. Right in the 14-15qt range. If you pull the pan you need 3-31/2 qt. If you pull the pan and filter you need right at 5qt. Damn, I can't believe I remembered all that. I quess I've done it too many times. haha
Old 06-04-2009, 02:13 PM
i used a truck dipstick and tube and bent it to clear the cowl.
Old 06-05-2009, 06:10 AM
forcd ind's Avatar
i was around 12-14 qts-i took a truck d/s, meas'ed how much of the stick came out past the bottom of the tube, cut down the tube/stick so it was back by the firewall, depending on the body style you have-the fluid level will be just above the pan/gasket when at the fill level
i had a pressure gauge hooked up when filling, was amazed it would build still build pressure as i added the last qt or 2, so correct fill is really important
Old 06-05-2009, 09:35 AM
MY99TAWS6's Avatar
Hmm I have a lockar dipstick planned to use for my swap. So its not going to read right?
Old 06-05-2009, 12:58 PM
forcd ind's Avatar
i think i have a tube/gauge hanging up somewhere, i could meas from like the rib on the tube to the full mark on the stick and give you an idea if your close
Quick Reply: How much oil will fill the 4L80e and PY-3400 stall
