help diagnosing an engine knock
Old 06-03-2009, 08:57 PM
nebur8's Avatar
Default help diagnosing an engine knock
only does this when it's warmed up. Starts at about 1500rpm-3500rpm. Here are a couple of videos. it sounds like it's coming from the driver side back of the intake area.
http://s705.photobucket.com/albums/w...t=06032009.flv
http://s705.photobucket.com/albums/w...6032009001.flv
Old 06-03-2009, 09:14 PM
bigboykilroy's Avatar
it kinda sounds like a bent pushrod, have you pulled the covers and checked them?
Old 06-03-2009, 10:34 PM
nebur8's Avatar
i haven't pulled the valve covers yet. I havent encountered a loss of power though.
Old 06-04-2009, 09:02 AM
nebur8's Avatar
when i remove the valve cover, what should i look for as an indication of a problem with the pushrods?
Old 06-04-2009, 01:10 PM
SOMbitch's Avatar
Take the rocker arms off. Then pull out the pushrods and roll them on glass tabletop or other flat surface and see if one is bent.
Old 06-04-2009, 05:51 PM
nebur8's Avatar
any other opinions?
