Help!
Help!
The past couple weeks, randomly it becomes difficult to shift in or out of the gears. I hit the clutch and when I go to shift to the next gear, it feels resistant to pull if out of gear and is tough to shift into the next gear. Its not like this all the time. Sometimes I can hit several stoplights and it shifts through the gears just fine. Its also tough to go into reverse when I first begin to drive (after the car has been off awhile). This problem just came up randomly....what you guys think?
Sounds like a slave or MC (or both) going out. As said above, if fluid is OK (level and color) go ahead and swap MC first, see if that fixes, if not move to Slave. Now here is the thing...if you have any miles on it, since tranny is down, you might as well do the clutch. Again, especially if you have miles on it. If you don't...then don't sweat it.
