Which fuse/relay controls the interior dome/rearview mirror lights?
The manual doesn't list those. I would just pull a fuse at a time and look to see if the metal filliment running in the middle if the fuse is broken or cracked. Use a flashlight for best results. I would check the courtesy fuse 1st. On the main fuse block under the hood. But your lights may just be out as well.
