View Poll Results: Solid or Poly MM?
Solid
19
55.88%
Poly
15
44.12%
Voters: 34. You may not vote on this poll
Solid MM regrets?
Old 06-12-2009, 12:28 PM
468CH3V3LL3's Avatar
Default Solid MM regrets?
Does anyone who has solid motor mounts regret getting them. Too much vibrations? I am trying to decide between solid and poly mounts. The only reason i would go solid is because of the fact that they're easier to install. I am puttin in poly tranny mounts as well. Also I've heard that solids raise the motor higher in the engine bay? Is this true? Any input is greatly appreciated!
Old 06-12-2009, 12:51 PM
Grifter's Avatar
I've had my Spohn solids on for about a year and half and so far I am happy with them. You can't really go wrong with either one. I think the install is pretty much the same for both, the only difference is you'll have to drill out the stock mounts for the poly's.
https://ls1tech.com/forums/generatio...or-mounts.html
Old 06-12-2009, 12:57 PM
PlatnumStatuz's Avatar
poly over stock, I've never run solid
Old 06-12-2009, 01:01 PM
3.4camaro's Avatar
Solid motor mounts don't transmit vibes nearly as much as the tranny mount. I have solid MMs and a stock rubber tranny mount. No vibes, nothing moves.
Old 06-12-2009, 02:27 PM
So u would recomend that i get new stock tranny mounts instead of poly mounts?
Old 06-12-2009, 02:52 PM
Grifter's Avatar
I thought I remember reading that you should not run aftermarket motor mounts without a poly trans mount. I think it had something to do with the trans and motor not moving together causing stress on various parts.
Old 06-12-2009, 02:58 PM
SMOKNSS's Avatar
I've had my spohn solids for a while now with the poly tran mount, but I have an adj. torque arm with a relocation crossmember. So far no complaints for me. Install is pretty much the same for both, except for drilling out the rivets on your stockers to put the poly pieces in the stock location.
Old 06-12-2009, 03:30 PM
MTN_Z's Avatar
My car does vibrate a little bit off idle but I have the same setup with a rubber trans mount. When I had the poly trans mount, it caused much more vibration than the solid motor mounts. No regrets here.
Old 06-12-2009, 04:56 PM
tripblackls1's Avatar
no running a stock trans mount is fine with solid or poly motor mounts
but running a poly trans mount with stock motor mounts is very bad
i wish i had solid motor mounts but my damn tube kmember does not allow
Old 06-12-2009, 09:08 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I got solid mounts on my CETA and wouldn't trade them for anything
Old 06-12-2009, 10:02 PM
SHovV's Avatar
looks like im goin solid when i get a k-member
Old 06-13-2009, 11:23 AM
Grifter's Avatar
Ok thanks, I knew it was one or the other.
I haven't checked in awhile but I think the Spohn k-member is the only one that allows you to run a solid motor mount.
Old 06-13-2009, 04:32 PM
Michael02hawk's Avatar
I have vouch for that....very bad!
Old 06-13-2009, 05:00 PM
SLOW 94 LT1's Avatar
Why is this? I've never heard that. It's also the exact combo I'm running in my car at the moment...
Old 06-13-2009, 06:01 PM
Z28M6TT's Avatar
im just going off of common sense, but im willing to bet the stock motor mounts with a poly trans mount is a no-no because the trans mount is just meant to take the force of the engine/trans pitching, not rotating. as in its designed for compression and tension. but if you have stock rubber mm's with a stiff poly tm, the tm is gonna be trying the take up the rotating force putting a side load on the mount (which its not disigned for). also im sure it puts a hell of alot more force on the tail housing of the tranny which already takes too much abuse from the tq arm imho.
Old 06-13-2009, 11:20 PM
NVR_SPDS's Avatar
Huh, i never thought about going solid, but reading everyones reviews, i think i want to now. I know pulling the trans will be a total bitch, but with an auto, i dont have a clutch or hydraulics to worry about.
Old 06-13-2009, 11:29 PM
Rafedial's Avatar
solid mounts in the car in my sig. A box or so of sound deadener on the floors and doors. vibrations aren't unbearable. gets the power to the ground more effectively IMO.
Old 06-13-2009, 11:48 PM
lowaggie's Avatar
I really like my solids. Like someone else before said, there is a little vibration coming off idle, but nothing crazy. I also have a poly tranny mount. They've been on for about 6 months or so now.
Old 06-14-2009, 02:25 PM
ShortChevy's Avatar
I've got solids and love them. I've also convinced friends who have rode in the car that they are fine for a street DD. Vibes are almost none existent. I did have a poly trans mount in there when I put the MM's in becuase the stocker was ripped in two. Now with the solid MM's and a stock trans mount there is only a slight viberation just off idle or when the car is cold and on high idle. I'd buy them again in a heartbeat and they are on sale right now at speed engineering.
Old 06-16-2009, 11:04 AM
Grifter's Avatar
It does make it more difficult but nothing too hard. I loosened the k-member bolts to help give me a little more room.
