Can you patch a MT Drag Radial???
IIRC, the reason for getting a drag tube is to pass tech. If you aren't worried about that, then you will be fine with the other tubes. If you put tubes in it, you are going to have to drill the rims if you have enough power to spin the rim in the tire.
I'd patch it if I were you. But I do have some BFG drag radials that I threw a plug in, and they are still fine. I can't hook worth a damn, but that is a different story
