how much can i expect to see?
hey guys, im going to be picking up a 6.0l truck motor pretty soon i hope, im going to be using the block of course, the crank and the heads off of it, as ive read that the stock crank and heads can hold up to a substantial amout of abuse. im still looking into what pistons and rods to go with, i know i need pistons that will give me a nice low compression ratio, im only going to be going .030 over on the block just to clean up the cyl. walls a bit, and having the heads slightly ported, again just to clean up the runners a bit, im going to use the edlebrock victor jr, intake with the 90* elbow, and the EPP forced induction cam, and im moving the turbo set up to the front...im just curious as to how much power i can expect to see if any one has an idea, im hoping for 700rwhp, but anywere in the mid to high 6's will do. thank's
its going to be a TC-76 and on low im planning on running anywere from 10-12psi and high im looking to be running about 20psi
