No start 1st try, start everytime 2nd try???
98 T/A bone stock
when you first start the car it will not start on the first turn of the key. it cranks and cranks but wont even begin to fire up. no matter how long or short you cranked the 1st time it will start right up with no problem the second time. even if you turn the key to on and back off and let the fuel pump prime a few times it wont start the first time. every once in a while it will start the first time after driving it and turning it off for a minute then starting again but not to often. its been like this since i bought it and i just got used to turning the key twice to start it but now im tired of it and need to address the problem. anyone have any ideas what it could be?
this sounds similar to my car. i replaced the fuel filter and fpr, thoses seemed to help but didn't really change anything. i replaced the fuel pump with a racetronix fuel pump and starts right away every time.
ill change the fuel filter and relay. seam foam scares me cause i hear to many horor stories. is there any kind of vaccum leak that could make this happen cause it sounds like i have one but i cant find it. spraying brake cleaner doesnt make it idle up so i dont know
im going to replace it. its weird that its the first time every time it wont start but it will the second everytime.
where is the relay your talking about? I just called the chevy house and he said there is no ignition relay only a starter relay. but the car cranks so its not the starter relay.
