Why aren't 396 LS1 Strokers popular?
Old 11-11-2003, 07:48 AM
Billiumss's Avatar
Question Why aren't 396 LS1 Strokers popular?
It seems 383 strokers (4.000" stroke) are very popular if your going to stroke a stock LS1 block, but why don't you see much about a 396 CU IN stroker?
3.903" bore & 4.125" stroke gives you a 396.
From the research that I have done so far, all you need is a 4.125 stroke crank (which Lunati makes) and you have to notch a few spots in the block to allow for piston/rod clearance, the same thing you need to do for a 427 engine.
Why go 383 when you can go 396 and get more torque? The costs are the same.
Is there something I'm missing here?
Bill
Old 11-11-2003, 08:02 AM
Dumb Ass Vette Moderator
ls1290's Avatar
The big problem with the 396 stroker package is deck height and oil consumption. Because the LS1 deck height is not that tall, the rod/stroke ratio is pretty poor and this leads to oil consumption problems.
Old 11-11-2003, 08:48 AM
Billiumss's Avatar
So if these statements are true, wouldn't a resleved 427 have the same problems? Deck height would still be the same.
Please explain more about the rod-stroke ratio.
Old 11-11-2003, 08:51 AM
LS1Tech Co-Founder
Nine Ball's Avatar
that 3.903 to 4.125 ratio is very undersquare. Most builders prefer square (equal bore and stroke) or oversquare (more bore than stroke). Oversquare engines tend to rev quicker than undersquare engines also.
396ci is popular with LT1 engines because that is the biggest they can get.
Tony
Old 11-11-2003, 08:53 AM
ls1290's Avatar
No, a resleeved 427 is a 4.125" bore x 4.0" stroke. The 0.125" difference in the cranks makes a huge differance.
Old 11-11-2003, 08:56 AM
93Polo's Avatar
The LT1 396 is still an oversquare design with bore of 4.03" and stroke of 3.875
The LS1 396 uses a 3.9" bore and a 4.125" stroke.
A sleeved 427 is oversquare at a 4.125 bore by 4.00" stroke or an Iron block is almost a square bore at a 4.06" bore and 4.125" stroke.
Old 11-11-2003, 09:24 AM
Billiumss's Avatar
So, it is possible, but not recommended to do a 396?
As for oil comsumption, is it because the piston crank pin is too close to the oil ring?
Any good books out there I can read to learn more about the do's and don't of engine building?
Old 11-11-2003, 09:47 AM
mattf2's Avatar
can't you do a 396 oversquare too? (LS1)
I always thought another SS396 would be cool.
Old 11-11-2003, 10:00 AM
93Polo's Avatar
Futral did a 393 sleeved motor. 4.125" bore with a 3.72" stroke offset ground stock crank? I could be wrong on the exact specs. You could get a 396 by adding a little stroke or bore.
TSP has an Iron block 396 4.06" bore and 3.82" offset ground stock crank.
Cubes= (Bore*.5)^2*3.14*(# of cylinders)*(stroke)
Old 11-11-2003, 10:06 AM
LS1Tech Co-Founder
Nine Ball's Avatar
Here, make it easier on yourself:
http://www.web-cars.com/math/displacement.html
Old 11-11-2003, 10:10 AM
mattf2's Avatar
I think Chris Pippy was talking about an offset ground crank w/ an .060 bored 6.0 iron block would go 396.
Old 11-11-2003, 09:04 PM
gillbot's Avatar
Bill, just get a 6.0 block and bore it 0.030 then get a 4" crank. Call it a 396 or a 409!
I'm actually planning on the 4.030 bore 6.0L block and the 4" crank myself sometime down the road.
Old 11-11-2003, 09:38 PM
gator's 99TA's Avatar
why is everyone caught up in cube numbers?
Old 11-12-2003, 03:51 PM
Billiumss's Avatar
It's just cool....
Old 11-12-2003, 04:17 PM
Scalpel's Avatar
It's just cool....
Yes it is
Old 11-12-2003, 04:24 PM
Technoman64's Avatar
Isn't there an old syaing there is no substitution for cubic inches. Or something like that
Old 11-12-2003, 04:37 PM
monkeyboy's Avatar
my buddy is in the process of doing an all bore 396. from what i understand, all bore 396 motors are superior to stroker 396 motors. is this true?
Old 11-12-2003, 05:03 PM
396" from stroke equals a big tq but a LOT of cylinder distance. it is way over square. for an all out drag motor, no doubt more bore is where it is at.
Old 11-12-2003, 06:27 PM
gillbot's Avatar
There's no replacement for Displacement.
Old 11-12-2003, 06:44 PM
DaveSchott's Avatar
remember most ss396's were actually 402's! put whatever badges on it and have fun, who'll know?
Quick Reply: Why aren't 396 LS1 Strokers popular?
