a/c not blowing cold....compressor?
aight lets start back in july of last year....blew the motor, had to pull and rebuild, etc. the a/c was obviously removed at this time (working perfectly), and then put back on the car a month later. ever since then, the air will not blow cold. we pulled a vaccum to get rid of the pound of air in the system, added freon, and it wont blow cold. the accumulator gets ice cold to the touch, the lines from it are ice cold too, just nothing but hot air in the cabin. the compressor also turns on just fine. is it possible that the shaft in the compressor was broken during removal/reassembly of the engine? this seems to be the only thing the a/c man knows it could possibly be. he had all sorts of mahcines and comps hooked up, i dont know too much about a/c......but that just seems WAY too coincidental to have the compressor go bad when i pulled my motor.
is it possible that the accumulator just got ruined? ive heard if they sit too long they are trash just bc of the moisture they trap.
Does the condensor ever get hot. Even just the metal line that connects right at the top corner of the condensor near the radiator fill cap should get warm. If it doesn't you're blocked up inside. Maybe do a flush.
try to put some more freon in it. If its cold for a few days then blows hot again, then its a leak. Our compressors have an o-ring inside that corrodes sometimes, your compressor could be working fine but leaking out where that seal is. If the freon works for a few days and then blows cold again, go to your local AP store and get some dye... run that through the system on full blast for about 10 minutes then shut the car off and get a black light and some of those orange tinted glasses, then youll find where your leak is and go from there.
Good luck, im dealing with this same problem as well and am going to run the dye on sunday.
