oil change light on?
hey just changed the oil of my car. but the oil change light is still on how do u reset it? or is it possible something else is trigging it. oh its a 2000 ws6. i little help would be appreciated. thanks
Read your owner's manual, but you should just be able to turn the key on, car off and then press and hold the trip reset button until the oil change light blinks/goes out.
1. turn the key to the on position.
2. slowly depress the gas pedal to the floor three(3) times in 5 seconds.
3.turn key off.
4.turn car on. light should have gone out.
5.reset the light every time you change your oil.
This works on most g.m.'s (including your f-body) and some mopar's
3.turn key off.
3.turn key off.
3.turn key off.
3.turn key off.
3.turn key off.
Thanks bud I need to do this also
If I've had the negative terminal disconnected for a couple days, will this reset the oil life indicator? Not that I'm really using it right now. But I'm curious. Thanks. Sorry for a hijak.
