Sponsored by: CARiD
oil change light on?
Old Jun 19, 2009 | 06:40 PM
romeric's Avatar
Question oil change light on?
hey just changed the oil of my car. but the oil change light is still on how do u reset it? or is it possible something else is trigging it. oh its a 2000 ws6. i little help would be appreciated. thanks
Old Jun 19, 2009 | 08:58 PM
91RS383's Avatar
Read your owner's manual, but you should just be able to turn the key on, car off and then press and hold the trip reset button until the oil change light blinks/goes out.
Old Jun 19, 2009 | 09:05 PM
Darksol's Avatar
1. turn the key to the on position.
2. slowly depress the gas pedal to the floor three(3) times in 5 seconds.
3.turn key off.
4.turn car on. light should have gone out.
5.reset the light every time you change your oil.
This works on most g.m.'s (including your f-body) and some mopar's
Old Jun 20, 2009 | 12:07 AM
Formula413's Avatar
^ Both answers are correct. ^
Old Jun 20, 2009 | 07:50 PM
oddwraith's Avatar
3.turn key off.
I always just used the trip meter reset method and until now I would have thought doing that with the gas pedal would have flooded the poor thing. Learn something new every day.
Old Jun 20, 2009 | 08:04 PM
qwickLT1WS6's Avatar
turn key to on position, hold the reset button for 15 seconds and then ur good to go
Old Jun 21, 2009 | 09:01 AM
bboyferal's Avatar
The "official" way is with the trip reset button...
In fact, on Trans Ams at least, the button itself is labeled, "Oil/Trip Reset."
Old Aug 18, 2009 | 10:45 PM
nitr0racing21's Avatar
3.turn key off.
Thanks bud I need to do this also
Old Aug 19, 2009 | 06:25 AM
firetpi's Avatar
Not unless you have a carb
Old Aug 19, 2009 | 06:32 AM
LS14EVR's Avatar
If I've had the negative terminal disconnected for a couple days, will this reset the oil life indicator? Not that I'm really using it right now. But I'm curious. Thanks. Sorry for a hijak.
Old Aug 19, 2009 | 07:12 AM
eseibel67's Avatar
^ no.
Old Aug 19, 2009 | 08:04 AM
LS14EVR's Avatar
^Thanks
