rebuild need advice please help!
ok guys i need to know a few things im tryin to order parts now for our friend to get on the trans. i was told i should get a new main shaft even if its just oem that 170k mile stock will give. also was told that 2nd gear is weak in early years yes? so far in my shopping cart on thegearbox site i have those 2 things and 3-4 steel fork with bronze pads. thats 400 i only have 100 left in my budget for it what do i NEED to tear into it. will things need to be replaced just because we opened it up? is 2nd gear needed? im tryin to go off the advice you gave and wat tick said. but my budgets tight. please help im tryin to get an order by the end of the day.
are the shaft seals needed? do i need shims for anything? bearings?
What year tranny is it? Unless the mainshaft is broke, why replacing it? Why are you rebuilding teh tranny in teh 1st place?
its a 95. i was told itd be a good idea to replace the 170k mile main shaft even if its with a oem one. and the rebuilt is for the 650+hp ill be putting through it. my hp estimate for the car on a 200 shot is around 700.
Billet Keys 3-4
Steel 3-4 fork
Bronze pads 1-4
New synchro *** 1-4
Carb Fiber blocking rings
do i NEED the 2nd gear were they really weak in the early t56's? and do i need new bearings? i know that 500 is a tight budget for what im goin to throw at it. im tryin to make it hold for the time. if i dont need second gear and dont need new bearings then i can get almost everything on that list.
Wel, is there anything WRONG with teh tranny now? Or are just kind of going through it to make it a little bit stronger? In other words, is there anything broke with teh tranny right now that you know of?
no the tranny shifted great and had zero problems that i know about at the time. but lik i said it does have 170k miles on it. idk about the guy before me but i drove the car hard. so no problems shifted great just need this thing stronger
OK, now we are getting somewhere. Well, with $500, cross out bearings (unless when you get tranny apart they are toast, but most times bearings hold up well, unless something breaks, contaminates fluid, and run through the bearing) but sounds like bearings are probaly OK.
I would also cross off mainshaft and 2nd gear. Why? If ain't broke, don't mess with it. You are gonna have trouble with the other parts 1st like synchro's/blocking rings/shift fork/keys, etc... I would replace all of those parts 1st.
ok here"s wats in my cart copied strait from thegearbox site. is there anything else. the totals at 436 so theres room. do i need any seals or anything?
T56 3-4 Steel Shift Fork W/ Bronze Fork Pads Tremec
$71.00 $71.00
Billet Keys for the 3-4, 5-6 OR Reverse Synchronizer Assembly
Keys needed:: T56 3-4
$60.00 $60.00
Bronze Fork Pads
Pads desired:: 1-2
$26.50 $26.50
Billet Keys 1-2
$45.00 $45.00
T56 3-4 Synchronizer Assembly
$109.95 $109.95
T56 1-2 Synchronizer Assembly
$71.00 $71.00
$60.00 $60.00
Bronze Fork Pads
Pads desired:: 1-2
$26.50 $26.50
Billet Keys 1-2
$45.00 $45.00
$109.95 $109.95
$71.00 $71.00
$60.00 $60.00
Bronze Fork Pads
Pads desired:: 1-2
$26.50 $26.50
Billet Keys 1-2
$45.00 $45.00
$109.95 $109.95
$71.00 $71.00
$60.00 $60.00
Bronze Fork Pads
Pads desired:: 1-2
$26.50 $26.50
Billet Keys 1-2
$45.00 $45.00
$109.95 $109.95
Need front and rear seal just to be safe, and some silicone
the forks 71 because it comes with the bronze pads. im gonna order this stuff now and if he finds somethin ill order it then. i already know i want these parts for the upgrade
upgrade? I've read about T56 stage builds, but you aren't going to be able to do it with that budget. If you just go about replacing a few weak spots then you will only find the other weak spots of the parts you didn't upgrade. So you need to either replace all of it or none of it. Save up and open the trans once and be done with it.
edit: if i put the trans back in completly stock im sure itd buy me the 500 mile of break in befor i messed it up.
I wouldn't feel comfortable reinforcing a few pieces of the trans with an engine laying down over 700hp into it. Then again, I think the T56 is rated up to 6XX hp and 6XX tq.
Iunno. Like I said, I'd play it safe and save a bit more and do it all out rather then just winging it and hoping everything goes well. I guess it depends on how long it would take you to save the money vs downtime in the future if you do break something.
im 19. i start college in 6 weeks i need to be done spending in 2 weeks ive spent 16k in the last 6 months. to save the 2k to do the viper rebuild thats needed would now take me yrs. im not 100% comfortable putting that much power through a t56 thats just been upgraded. but at the time its kinda the only choice i have
