Intake Air temp Sensor
Old 06-28-2009, 08:59 PM
jojomanx's Avatar
Question Intake Air temp Sensor
Im unsure which is the color code of the air temp sensor. Does anybody know?
I aquired a second hand wiring harness and well I have had to figure some of it out myself.
By the way, I bought a LS3 serpentine kit and the AC comp does not fit. I will sell it with the belt and mounting kit for a fair price. I need AC!
Old 06-29-2009, 06:37 AM
69LT1Bird's Avatar
What is the harness out of? What do you mean by color? Connector color, wire colors?
Old 06-29-2009, 02:52 PM
jojomanx's Avatar
Question
98 camaro wiring harness.
I believe the connector to the air temp sensor was cut off.
I would need the wire color code to the sensor.
Old 06-29-2009, 07:29 PM
69LT1Bird's Avatar
Get a different harness. What PCM are you planning on running? 98's are junk.
You will need to repin the PCM part of that harness to run a newer PCM. What MAF are you looking to run, if you are planning on a 85mm, get the correct harness now and be done with it.
Old 06-30-2009, 06:55 AM
jojomanx's Avatar
Im going to have to keep what I have til next year.
Can anybody check their air temp sensor wiring for the color code?
Old 06-30-2009, 06:56 AM
jojomanx's Avatar
By the way ls1 tune updated the map and eliminated the items I dont need.
Old 06-30-2009, 07:04 AM
69LT1Bird's Avatar
I found this on another site.
At the PCM:
C1 (Red) PCM connector: Pin 8 Tan - Signal wire
C2 (Blue) PCM connector: Pin 21 PPL - ground wire
Old 06-30-2009, 08:29 AM
Kleeborp the Moderator™
MeentSS02's Avatar
Moved from Fueling and Injection - this is a better fit in this section.
Old 06-30-2009, 11:44 AM
jojomanx's Avatar
At the PCM:
Great! Thanks!
Now, tell me about why I should update my ecu. Specifically the detailed advantages and your ideas of what you have done.
Next year Im upgrading a few things.
Old 07-05-2009, 06:26 AM
jojomanx's Avatar
Thumbs up Thanks
Thanks to all that help on this site.
My BMW LS1 is running better every time.
Quick Reply: Intake Air temp Sensor
