Wiring Diagram
Wiring Diagram
I know i can piece a few diagrams together for my setup, but just trying to see if anyone has a diagram of my setup; I have the cold fusion kit with msd window switch 8969, purge kit, and wot switch. Should i get a fpss if i just put in a new walbro 255?
Me either. I thought it was a gov computer issue. I'll fix it when I get home
OK, basically you send one wire from the noid to ground, and the other to the 87 pin of the relay.
30 pin goes to the battery
85 goes to ground
86 goes to switch
other side of switch goes to keyed 12 volt
85 goes to ground
86 goes to switch
One more quick question i have a 60 amp relay and a 30 amp relay, which one should i use where. 60 amp on solenoids and 30 amp on the purge? Thanks again for any help
